Question about Sport & Outdoor - Others
I have a 6-8 persons tent by NORTH POLE (Northwest Terr.) that i bought several years ago from Walmart and now seem to lack all the fiberglass poles. where can a go to find some?
Posted by Dietrich Weissinger on
Jean DeLauche
  • 2,911 Answers
Hello, Dietrich -
I believe North Pole Ltd., maker of North Pole tents, headquartered at one time in the St. Louis, Missouri area (with products manufactured in China) is no longer in business. I found some newspaper articles dated 2012 and 2013 indicating the company had financial problems and went into receivership (bankruptcy.)
However, I did find a blog from 2013, My Favorite Camping Store,
http://www.my-favorite-camping-store.com/important-update-for-replacement-parts-northpole.html
which provided a link to a tent pole replacement business, TentPole Technologies:
http://tentpoletechnologies.com/
This is a link to another business, Quest Outfitters, mentioned in the blog:
http://www.questoutfitters.com/tent_poles.htm
Best wishes.
Posted on Jun 05, 2018
5 Related Answers
Anonymous
  • 41 Answers
SOURCE: Tent
Well, you should have Three (3) longer poles and Two (2) shorter. Two (2) of the longer poles will be the basic construction poles. They will basically make an "X" across the top of the tent making the four courners of the tent. The other longer pole with also go across the top of the tent and right through the "X" made by the other two (2). This will push out the sides and make is "dome-like".
The two (2) shorter poles will go on either side of the enterance. These will hold up the sides of the tent to give you more volume space on the inside. Not exactly nessasary but if you want more than one or two people to fit inside, you'll need these.
Hope I helped.
Posted on Oct 15, 2008
Anonymous
  • 160 Answers
SOURCE: Centre pole is failing to hold tent up in any real wind
TRY DRILLING A SMALL HOLE ON THE INNER POLE SLIGHTLY SMALLER THAN THE DIAMETER OF THE SCREW. U WILL WANT TO DRILL SMALL HOELS EVERY FEW INCHES(CM) SO THAT U WILL BE ABLE TO SET THE POLE AT VARIOUS HEIGHTS IN THE FUTURE.
Posted on Jan 14, 2010
mcdugal2
Philip Rhoades
  • 4 Answers
SOURCE: square tent with 2 types gazebo poles, varenda, 2 side windows
the 2 longest of the poles go in an x over the center of the tent and the 2 shorter ones go arch to the sides. http://www.wenzelco.com/details.aspx?NavID=412
shows a picture very similar to your tent. If you go to image 2 it shows it with out the fly. now if you got 2 sets of 4 poles, 2 long and 2 short, and one set is all aluminum, then I would go with the aluminum set. It is less likely to collapse in high winds.
Posted on May 04, 2010
shopper426
SOURCE: I have a coleman Weathermaster
I have the same model number tent and have some broken connectors as well. I could not find any replacement parts any where local or online. I called Coleman's customer service number at 800-835-3278. The tent has been discontined but they had a few of the connectors "in the office" and shipped me three. Give them a call; they were extremely helpful. Coleman customer service is top notch in my book!
Posted on Mar 28, 2011
kate
  • 70 Answers
SOURCE: I am looking for some fiberglass roof tent poles for the Ridgeway Moab 89034
did you search google
Posted on Jun 07, 2012
I have a North Point screen tent and I would like to replace the poles. Anyone know where I could order them from?
Hello, Amy -
Apparently Northpoint Adventure Gear was a private label sold by Sports Authority stores. Sports Authority filed for bankruptcy in 2016 and ceased doing business. For a while, after Sports Authority ceased doing business, information on its website directed those interested to Dick's Sporting Goods.
I only find a tent pole repair kit being sold by Dick's Sporting Goods, currently, in stores only:
https://www.dickssportinggoods.com/p/coghlans-tent-pole-repair-kit-16cghufbrglsstntpcat/16cghufbrglsstntpcat?
If you still have the poles for your Northpoint tent, do not toss them out, just yet.
I have seen a variety of replacement tent poles for sale through Amazon. You MAY be fortunate enough to find replacement tent poles which will work with your Northpoint tent for sale there.
Best wishes.
May 12, 2018 | Sport & Outdoor - Others
Do not have instructions how to set it up?
What type of tent?
Typically, aluminum poles are "vertical",
while fiberglass (flexible) poles are "horizontal" (to support the top of the tent).
Aug 21, 2015 | Sport & Outdoor - Others
I have had a tent donated to our agency. Where can I get directions for erecting and finding missing parts?
This tent was made by NorthPole, which has closed its parts department. Check this notice, which does list some places you might be able to get some parts.
I caution you that this was a department store tent, made to hit a price point, and sourcing a few parts might cost far more than the tent it worth.
Aug 05, 2015 | Northwest Territory Family Cabin 8-Person...
How do I assembly the tent
Step 1 Remove the tent, poles, stakes and tent rope of the dome tent from the Northwest Territory sack. Locate a large flat area and remove any sticks and rocks from the ground. Step 2 Lay the tent fabric on the ground with the bathtub style floor face down. Pull the corners of the fabric tight and rotate the tent so the door is facing in the direction you want. Use a hammer to stake the corners in the ground. Step 3 Assemble the two long poles to their full length. The pole segments are connected by chords and will easily snap into place. Slide one pole through the diagonal sleeve on the top of the tent. Slide the other pole through the other diagonal sleeve to form an "X" with the poles. Step 4 Place the end of each pole in the corresponding grommet. The poles will bend and the shelter will be erected. Step 5 Assemble the two small poles. Slide one pole in the doorway sleeve and the other in the back window sleeve. The poles will bend slightly to create a rain peak on the door and window. Step 6 Pull the doormat tight and pound stakes through the loops on each corner. Pull the tent rope tight on the back of the tent and pound a stake through the rope loop to anchor the tent to the ground.
May 31, 2015 | Northwest Territory Sierra Dome Backpack...
I have a ten year old tent hardly used that has somehow now minus its tent pools can i get replacement ? how ? and How much
Sporting goods stores normally carry generic replacement poles- you want to find pole of the same diameter. These can carefully be cut to size by securing the cord between the first & second pole, cutting the knot at the end of the pole, then sawing off the end of the first pole that does not have the metal coupling. This is easier if you wrap masking tape around the pole at the cut location to help prevent the fiberglass from splitting. Put the cord back through the first pole, tie a couple of figure 8 knots, and you are good to go.
Nov 25, 2013 | Sport & Outdoor - Others
I have a coleman Weathermaster tent I bought a couple of years ago the model number is 2000002250 the issue im having involves the plastic elbows that come with the tent that ties the upright tent poles to...
Mar 06, 2011 | Coleman Sport & Outdoor - Others
Need instruction manual for the Ridgeway Moab Model 89034. 4 room tent
I borrowed one of these and got most of the job done. Here's what I ended up doing:
At a site with good drainage, a little uphill, stake down the floor of the tent
Longest two poles go through the twin sleeves in the center/top. They are color coded red and yellow
These two poles are anchored at the base by the center color coded ring_peg
The tube ends of the fiberglass poles. Fit over these pegs.
The slightly shprter fiberglass poles go trhough the two blue sleeves.
These poles get anchored on one end by a yellow ring peg and on the other by a red ring peg. They hold the vented windows up.
The arch shaped pole is threaded through a black sleeve atop the entrance to the. Tent.
The arch is anchored on either side by a red ring peg on one end and a yellow peg on the other.
Stake the lines from the screen windows outwards from the tent
Spread the tarp over the top and stake the corners to shelter the screened top from rain
Aug 23, 2010 | Sport & Outdoor - Others
General instruction manuel
Assemble all the poles, thread poles through sleeves, connect one end of the poles to the tent, stand up one by one! North face and sierra design tents are tricky at first but get easier the more times you do it!
Oct 03, 2009 | The North Face Foundation 6 Bx Tent...
Need replacement poles for Cabin Tent
Do you have a Northwest outlet in your area? Otherwise you can get it from the manufacture.
Jul 06, 2009 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
Sport & Outdoor - Others Logo
776 people viewed this question
Top Sport & Outdoor - Others Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
