Your PC needs analog inputs
Something like this..
https://express.google.com/u/0/product/14298305064172019109_3260720217869721385_1057813?mall=WashingtonDC&directCheckout=1&utm_source=google_shopping&utm_medium=product_ads&utm_campaign=gsx&utm_content=control_45_60&dclid=CKz6kJeWh9wCFYbNZAodq5cHiQ
Use analog converter device to transfer VHS signal to computer. the steps are part of this VHS to DVD tutorial you can learn more there. VHS to DVD Tutorial How Can You Convert VHS to DVD at Home
Connect a set of RCA audio and video cables to the color-coded outputs
on the back of your Samsung VHS/DVD player. The colors of these cables are
yellow (video), white (left audio) and red (right audio).
Take the other end of the RCA audio and video cables and connect them to
the color-corresponding inputs on your television. When plugging in these
cables, look for a label for the input, such as "Video 1" and
"Audio 1." This will be important in Step 5.
Turn on the television and the Samsung VHS/DVD player.
Tune your television to the video input channel that you noted in Step
3. If you did not take note, you can also tune through your television's input
channels until you find the one displaying the signal from the DVD/VCR player.
Insert a VHS tape or DVD into the Samsung player and press the
"Play" button to verify that the unit is functioning properly.
Component Video
Plug the power cable of the Samsung VHS/DVD player into an available
power outlet near the television.
Connect a set of component video cables to the color-coded outputs on
the back of your Samsung VHS/DVD player. These cables will look similar to
composite audio and video cables, but they are instead color-coded as red, blue
and green.
Plug the other end of the component video cables into the
color-corresponding inputs on your television. Take note of what input number
you are plugging the cords into, as it will be useful later.
Connect a set of RCA audio cables to "Audio Out" jacks on your
VHS/DVD player, then connect the other ends to your television. These cables
are color-coded as red and white and must be plugged into the same input number
as the component video cables.
Tune your television to the component video input channel where you
connected the Samsung VHS/DVD player.
Insert a VHS or DVD into the Samsung player and press the "Play"
