It is for a 2014 Husqvarna Trimmer 128LD; cannot find the QCJ-8Y anywhere!
According to the Husqvarna manual the OEM spark plug is a Champion RCJ-6Y gapped at 0.024 in.
The NGK BPMR7A is readily available.
See following link for more alternatives.
https://www.sparkplug-crossreference.com/convert/CHAMP_PN/RCJ6Y
Here is the exact one you need: Husqvarna 531300688. You can buy it on Amazon for less than $5.00. IMO far better to use Original Equipment parts than to use aftermarket. I am not a fan of Champion Plug.
Amazon com Husqvarna 531300688 Spark Plug Chain Saw Accessories Garden...
SOURCE: i need a owner user operating instruction manual
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_545196750.pdf
here is a link to the pdf file to huskies website hope this helps, you can print off some or all of the owners manual free of charge.
SOURCE: No Spark - Husqvarna 125R Trimmer
Check the wire that goes to the "OFF" button. See if it is by chance loose or cracked allowing a short. Beyond that, it would probably be the coil, but I would lean towards some type of a short, especially if you know the plug is OK.
SOURCE: My Husqvarna 128ld trimmer will run but only at
guys,
the d shaped tool is also carried as an MTD part. see your local dealer.
If not google walbro d cut tool ad see what you get. They're on solo
chainsaws as well
The next step is to richen the fuel mixture on the H screw on the carb, there is a special tool required to turn the adjuster screws because they have a splinr rather than a screw driver slot, the tool is part np. 530035560 unscrew tthe H screw 1/4 turn anti clockwise.
