Question about Jensen GPS
GPS SD card data carrier for Jensen JNA - Jensen GPS
Posted by Amanda Tabisher on
5 Related Answers
smartinks
SOURCE: my gps will not recognise my sd card or turn on
Try the clear flash utility. It worked for me. Martin
Posted on Sep 23, 2007
Anonymous
SOURCE: how to use sd card with magellan meridian gold
http://www.mtgc.org/robertlipe/MeridianFAQ/#47.Troubleshooting%20–%20My%20tracks%20have%20the%20wrong%20time%20stamp?|outline
Try this site to trouble shoot your problem! Good Luck! I ran across this today trying to trouble shoot mine.
Dave
Posted on Sep 20, 2008
Anonymous
SOURCE: Jensen VM9512 - 4GB SD Card won't work
I use a scan disk 2 or 4 gb and both work just fine.
Posted on Apr 28, 2009
Anonymous
SOURCE: I donĀ“t known how watch videos on SD card - Jensen vm9512. Format
yes you can watch video
I alredy did it in my jensen
all you have to do is:
xvid avi
video codec: mpeg4
video bit rate: 887kbits/s
video size: 576x320
aspect ratio: 16:9
set this setting in total vide converter
do the convertion and that's.
Posted on Aug 08, 2009
KiwiGPS
  • 59 Answers
SOURCE: Micro sd card not showing up on the gps
Have you got GB Discoverer on the card? The map should appear on the Map Information list in the Setup > Map area. Double check the placement of the map card. Also, in case you have not found it yet, there's wealth of information on the Oregon Wiki here: garminoregon.wikispaces.com
Posted on Nov 04, 2009
My tom tom one when i swith on the screen shows the sd card being removed from tom tom with a red cross across sd card.the sd card is in side .i can not past this screen or use gps how do i fix thanks
It is likely that the SD card (data) is corrupted. I'm assuming that it had previously worked properly.
Have you tried running a (fix) disk utility against your (internal disk or SD card) storage for the GPS ?
For instance, connect the GPS to your PC (Windows), and select (highlight) the (internal) "disk" on the GPS device. Under File - Properties, go to the Tools (tab) and run the "Error-Checking" option.
This utility may fix your data error.
If not, consider doing a restore (from backup) of your GPS disk storage.
Mar 24, 2013 | Tomtom One XL GPS Receiver
Lost maps
You do not give very much information to go on.
Perhaps you have downloaded some data such as routing or some other details from your computer via "MapSource". If so AND you have a mini SD card in the GPS, you have overwritten the SD card with the data from MapSource ...the map data on the SD card is now gone!
But the MapSource Data remains.
If you have copied the original data on the SD card, just copy and paste to re-place it.
If NOT you will need to contact Garmin to get a new SD data card.
What you have to do to prevent this in the future is to temporarily remove the Data Card from the Garmin GPS, then download the MapSource data from your computer. Then the MapSource Data goes to the GPS on-board memory.
Jul 21, 2010 | Garmin GPS
Nov 02, 2009 | Garmin Oregon 550t Handheld GPS Receiver
Navigon 5100 SD Card problem
I woulod think the data is corrupted or not in ther format the GPS is expecting. redownload the data to the PC desktop and see how it is organised
Jul 21, 2009 | Panasonic Navigon 5100
I have a Nokia 500 gps system. The sd card with
Try to fix the sd card with some recovery software (recuva or similar) and transfer the data to a new card. If you have the installation disk, use that to copy the data to a new card. Do not use the corrupted card, since you might lock up the device for good.
Jul 14, 2009 | GPS
I load regions to sd card and meridium platium does not recognize
You do not need to screw with an SD card, they are formated to take whatever data you send to them, but in your case check by reading the card to see what is on it BEFORE you put it in the GPS. It may have junk files on it, thus there is no room, unless of course you try to load to much data, THERE IS A LIMIT, suggest you read the GPS manual, and see what the limit of the size of the card is for that GPS, yes there is a limit!
Jan 13, 2009 | Magellan Meridian Platinum GPS Receiver
SD Memory Card Software For NVX200
please i need help my memory card got stolen and my gps is not working and all i need is the software because i have bought another memory card so please text back its a jensen nvx200 audiovox navigation and was online for hrs. looking for the softeare so please text back
Oct 13, 2008 | GPS
GPS Logo
95 people viewed this question
Top Jensen GPS Experts
Marvin
Marvin
Tom Chichester
Are you a Jensen GPS Expert? Answer questions, earn points and help others
