Question about WMF Coffee Makers & Espresso Machines
Error code 161 WMF espresso machine, commercial machine, help
Posted by Hope Frost on
timoboon2
    Sergeant:
  • 360 Answers
Just contact WMF for the problem. They can help you out.
Posted on Jan 23, 2019
5 Related Answers
faith_hands_
Ren Filkins
SOURCE: I have a wmf presto coffee machine with an error
Download the Manual online. There is a Section that is for Diagnostics. I will tell you what the code is and how to replace it. Use the Model Number to get Manual.
Posted on Sep 15, 2014
Anonymous
SOURCE: manual for espresso/cappucino machine
The Miele manuals are available on the Miele site.
Posted on Mar 29, 2008
EsWorld
Ernest R
  • 1618 Answers
SOURCE: Espresso machine not steaming
If the machine heats up for coffee, then the steam wand tips are probably blocked. Use a paper clip or needle to clear out the holes at the end of the steam wand.
Posted on Jul 03, 2009
Anonymous
  • 192 Answers
SOURCE: error code 161 ? ibm 380ed
you have not give us the detail problem, when/where you are getting this error?
Posted on Apr 01, 2010
vdbpieter
vdbpieter
SOURCE: we have the error 5 at the WMF coffee machine . please help what we do?
Just had the same problem today.
It seems that it's the grinder inside that's not placed correctly or dirty or jammed... just get the "brownish" thing out... See that everything turns as it should, that it's quite clean and put it back. Restart machine and then it should work
Posted on Aug 30, 2012
WMF Presto/schaerer coffeee machine error 167
Usually this is caused by a blockage in the steam boiler fill pipe when it timesout. This can get filled with limescale where running a descale program is not enough, it is too late. You will need to manually strip down the machine and remove the scale from the steamboiler fill pipe. Usually and 8mm drill bit is enough to remove it. It is also worthwhile removing the level probe and cleaning while the boiler is depressurised and cooled down. Once reassembled, run the descale program again.
2answers
I have a wmf presto coffee machine with an error code 186, how do I solve this
2answers
Error code F187 on a wmf 1200s, any suggestions on how to fix it
KOD BLEDU CODE ERROR F87 F187 W WMF 1200, WYSTARCZY WYJAC Z BOJLERA CZUJNIK TEMPERATURY PRZELUTOWAC NA NOWY ZA 1,5PLN /0,4EURO ,79f38919-05c3-4d8a-b59d-1f0cb67501ce.jpg
2helpful
My wmf prestolino displays error code 187 when i turn it on. What does this mean ?
change the termistor from the top of the biger boiler with NTCM 10 ohm and that is the best solution 100% works
4helpful
We have the error 5 at the WMF coffee machine . please help what we do?
Coffee Makers & Espresso Machines Logo
Top WMF Coffee Makers & Espresso Machines Experts
Pierre Laplante
Kolbrun...
Ross Keen
Are you a WMF Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
