Question about Weather Channel Measuring Tools & Sensors
The weather channel how do I reset the outdoor temp?
Posted by Barbara Gale on
Tom Chichester
    Top Expert:
  • Weather Channel Master
  • 55,960 Answers
  • Remove all batteries from both units
  • Install known-good batteries in outdoor unit. Allow time for outdoor unit to initialize and begin sending data
  • Install batteries in indoor unit. You should see outdoor temperature displayed
Posted on Jun 05, 2018
4 Related Answers
kb8dns
Rod Wallberg
  • 494 Answers
SOURCE: dashes in my outdoor weather reading of Oregon Scientific station
The signals are not being received by the main unit. Try to reposition the unit or move it to a different location. Also make sure the antenna is in the clear and not next to any thing like a cordess phone or charger as these can make RF noise that can block or cover the needed signals.
Posted on Feb 11, 2010
19ken55
Ken Fowler
  • 426 Answers
SOURCE: Sprigfiel Precise Temp Weather center
try power down for a few and attempt change immediately after power on
Posted on Jan 08, 2011
AndrexT
Andrew Taylor
  • 33315 Answers
SOURCE: i have the weather channel indoor outdoor thermometor and the outdoor temp and humidity are not showing up on my wall reader
With mine, this indicates that the battery needs replacing on the INDOOR unit. For some reason they don't pick up the signal from the transmitter. I use batteries 3 to 1, indoor to outdoor.
Posted on Feb 23, 2017
  • 18397 Answers
SOURCE: I have an Acurite weather station, model 02080, and when I place the lightning sensor outdoors as it states in setup, outdoor temp is indicated. How do I set it up to work properly?
The display has the internal sensor for temp and barometer, The 5 in one has the sensor for outdoors and shows temp, wind speed and direction, humidity and rain. With the added lightning detector having the additional temp sensor in it, the system is redundant. It is recommended to put the sensor outside for best results that t have the least interference and maximum range..
Posted on Apr 01, 2018
I have the weather channel indoor outdoor thermometor and the outdoor temp and humidity are not showing up on my wall reader
Feb 23, 2017 | Weather Channel Measuring Tools & Sensors
Will not transmit outdoor info. Batteries good- LED lights. Monitor shows indoor temp only.
There are a couple of possibilities for the failure to transmit/receive outdoor data. First, resynch the two units. This will depend on the manufacturer. For some brands, you need to take the batteries out of both the indoor and outdoor units for 10 minutes. Then put the batteries into the devices with both side by side (working inside is easier). Wait until the outdoor data is displayed. There are some weather station systems where the outdoor unit isn't weather-proof. You may need to dry the outdoor unit for several days after removing the batteries before resynching it to indoor sensor.
If the data displays properly when the outdoor unit is inside, you may have the outdoor sensor too far away from the indoor unit. (The distance will depend on the number of walls and the composition of the wall studs/siding.) Try keeping the two units closer together.
If the outdoor data isn't displayed when the two units are side by side and the reset procedure doesn't work. One device has an internal malfunction (transmitter or receiver failed). It's probably best to replace the unit. If it is under warranty, contact the manufacturer.
I hope this helps. For specific details on resetting the indoor and outdoor units to synch them, please add a comment with the make/model of your weather station.
(I've seen Davis Weather stations damaged by a close lightning strike. The outdoor unit had to be replaced.)
May 23, 2015 | Measuring Tools & Sensors
Outdoor temperature reading shows -40 with wind chill -62. Outdoor temp is in fact +45.
We would recommend a hard reset of your Weather Station. Please verify that you are using a good-quality, standard alkaline battery such as Energizer or Rayovac, and then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall battery into the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or [email protected]
Mar 17, 2015 | Chaney Measuring Tools & Sensors
I See my Outdoor temp. Nothing
What do you mean nothing? How are the batteries? What channels are you using?
Feb 22, 2013 | Oregon Scientific BAR386 Wireless Weather...
Instructions for springfield precise temp model 91455
I also reset my 91455 today. Go online to Springfield precise temp manual 91455
May 29, 2012 | Springfield 91455 Wireless Digital Outdoor...
I have a 433MHz cable free indoor/outdoor thermometer. It has worked perfectly for years. Just changed the batteries in the main unit and the remote. The main unit will not pick up the outside temp. I...
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Sep 17, 2011 | Oregon Scientific Wireless IndoorOutdoor...
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
Measuring Tools & Sensors Logo
359 people viewed this question
Top Weather Channel Measuring Tools & Sensors Experts
john h
Andrew Taylor
Andrew Taylor
Are you a Weather Channel Measuring Tool and Sensor Expert? Answer questions, earn points and help others
