Question about Taylor Health & Beauty
SOURCE: weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Posted on Aug 25, 2008
SOURCE: Taylor Scale 7532s - not working
This link allows you to trouble shoot directly with the company....I hope this helps.
http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
SOURCE: Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Posted on Mar 14, 2009
SOURCE: how to calibrate a taylor scale 5571
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
If
the reset is successful, you should receive a weight right away. If you
continue to receive one of the error messages above please call our
Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Posted on Nov 29, 2009
SOURCE: how to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Posted on Aug 26, 2010
Jun 24, 2015 | Health & Beauty
Aug 01, 2014 | Taylor Health & Beauty
Jun 06, 2014 | Taylor & Digital Scale Lithium Scale
Feb 10, 2013 | Taylor 5568 Fat Scale Stainless Steel ()
Jan 10, 2011 | Taylor 55684102 BODY FAT BODY WATER...
Apr 02, 2010 | Taylor 5599 440 Pound Tempered Glass Body...
Sep 04, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Jul 29, 2009 | Health & Beauty
Jun 13, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Dec 18, 2008 | Taylor 7532 Ultra Thin Glass Digital Scale
551 people viewed this question
