Question about Simbans Tablets & eReaders
I hold my power button and volume botton but my simbans tablet wont turn on even when charged
Posted by Nicholas Golden on
Anais Lepers
    Dedicated:
    Visited the website for 20 consecutive days.
  • 50 Answers
If you feel like fixing that power button switch yourself here is a link for parts and free repair guides https://www.sosav.co.uk/store/1414-tablets
Posted on Jun 07, 2018
Vincent
    New Friend:
    Problem Solver:
  • 9 Answers
Sounds like the power button switch has given up on you. With a lot of care and time, you can fix this yourself for a few dollars if you buy the part and tools on eBay, or you can just take it to a repair shop.
Posted on Jun 06, 2018
5 Related Answers
SOURCE: Micro Cruz Tablet Wont hold charge
Well, I think you should change the battery of your tablet PC. You must have charged the tablet for more than enough time several times. so the battery is damaged. or, the battery must be used for a long time!!!!!!
Posted on Jun 27, 2012
benjamin_951
Benjamin Simoni?
  • 53 Answers
SOURCE: my tablet is not powering on..it is getting charge
Two most probable problems:
-bad battery
-bad motherboard
If it's still under warranty, get it repaired.
If not, buy a new one
Posted on Oct 13, 2013
cougar123
John Sweeney
  • 77 Answers
SOURCE: the 7 inch tablet when you turn it on shows the 2 dogs then goes to rca logo and nothing else. tried to reset by holding power & volume button at same time, did not work
contact vendor mfg - shoulds be under warranty
Posted on Jul 11, 2014
mike0862
Mikey
  • 6269 Answers
SOURCE: holding the power and volume button to rest and its not working on the xtreme tablet generation 2. what do I do now
To do a soft reset so you do not lose any data just press power for 15seconds........then it will restart!
Posted on Jan 01, 2015
amya
SOURCE: My tablet wont turn on I tired lots of ways to try in reset it I even try the reset button in the back plz help me I only had it for like a month
O tired. To trun it on but it does not working. And it on a 100 plz help tell me what i have do to get on
Posted on Feb 25, 2015
My son's tablet is less than 4 months old and it keeps shutting off even when fully charged. It is a 9 inch nextbook and was purchased at Walmart.
Hold the volume UP botton down when it is OFF, then while holding that button down press and hold the power on button and keep both pressed for about 10 seconds. Then release.
Feb 23, 2017 | Nextbook Tablets & eReaders
Allwinner a33 tablet wont charge or power on
Plug the tablet in, and try holding volume up + power buttons for 15 seconds or until something happens. If nothing happens, try holding volume down + power buttons for 15 seconds or until something happens.
Dec 13, 2016 | Tablets & eReaders
User manual simbans ultimax 10'' tablet
Your manual is here.
Turn your device on and off To turn on your device, press and hold the power key.
To turn off your device, press and hold the power key, and then tap Power off?OK.
Manuals
Dec 29, 2015 | Simbans Tablets & eReaders
How do i fix my asus tablet its froozen on screen cant turn it off
Take a flat object like a butter knife, start near a corner and pop the back cover loose...then work your way around removing the cover, pull the battery out, press and hold the power button for a few seconds, put the battery back in, put the cover back on, turn the tablet back on.
Feb 17, 2015 | ASUS MeMO Pad HD 7
Nobis nbo7 froze so I pressed reset now it won't power on or do anything
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button.
Feb 02, 2015 | Tablets & eReaders
Tablet got frozen on go screen so I pressed reset now it won't do anything not even turn on
What tablet brand is it? Need to configure reset duration on hold buttons
Forgot parren to unlock tablet
You need to factory reset! from off, press power and volume+ buttons together until reset screen comes up, then move using volume and select using power buttons!
Jan 01, 2015 | ZEEPAD 7 inch Android 2.2 Tablet
Why wont my proscan android tablet turn on ?
If you haven't done so already, try holding the power button down for a long time (30 seconds+) when you switch it on. If no success, try again but hold down the power button *and* the volume-up button when you switch on.
Aug 10, 2014 | Proscan 7-Inch Android Internet Tablet,...
Charging problem google nexus 7
i have a problem with my nexus7 and it want charge or turn on please help me with this problem
Jan 16, 2013 | ASUS 32GB Google Nexus 7" Tablet with...
Etouch android wont charge
switch off.wait for 5 mins.
connect to pc or laptop with usb cable.
press & hold power button till it turns on then off.
press power button for 3 secs.it should work.
if no luck try this-
switch on by pressing power button while holding volume + and -.
keep hold of both until powers on.
can take few mins.
good luck!!!
Jun 27, 2012 | Tablets & eReaders
Tablets & eReaders Logo
164 people viewed this question
Top Simbans Tablets & eReaders Experts
 Mikey
Mikey
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Simbans Tablet and eReader Expert? Answer questions, earn points and help others
