Question about Electrical Supplies
I have a cummins onan RVQG2500 LP MODEL 2.5KVD-2089B S/N F100127426 AND THE question is;; starts and runs , then stops when the start switch is releaed ?
Posted by jerome lyons on
Carl Rock
  • Electrical S... Master
  • 2,442 Answers
See trouble shotting guide
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.flightsystems.com/pdf/onan-rv-troubleshooting-guide.pdf&ved=2ahUKEwjI49Gf48_pAhWMVc0KHWX4DMIQFjAAegQICBAB&usg=AOvVaw2R1u0OvWwmNjVdXisAdjGI
Q. Why does my generator start and then shut down as soon as the start switch is released?
A. Most models require both oil pressure and AC voltage from the generator to keep running. A lack of AC voltage can
be caused by a variety of problems involving the control board, regulator, generator and wiring. A stuck oil pressure
switch can also cause this symptom. The interaction between the various components of the system can be confusing
during troubleshooting. Use the Troubleshooting Guide to isolate the problem.
Posted on May 25, 2020
sherlywang
    Master:
  • 425 Answers
You should if the fuel is enough and if the start motor is good or not
5 Related Answers
mamicheddy
mamicheddy
  • 79 Answers
SOURCE: Only runs if I hold the start switch
The problem is that you are not creating voltage. Remove front cover. Place a volt meter on the breaker. Start genset and you will see no voltage present. The problem could be with the brushes, rings, rotor, stator, voltage regulator, or control board.
Posted on May 09, 2009
Anonymous
  • 77 Answers
SOURCE: onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Posted on Aug 10, 2009
Anonymous
  • 160 Answers
SOURCE: I have a 6500 lp onan marquis generator in my rv.
ONANS ARE PRETTY QUIRKY AS IT IS NOT CONSUMER FRIENDLY. THE GENSET IS DESIGNED FOR ROUTINE AND SIMPLE MAINTENANCE PERFORMED BY THE OWNER, AFTER THAT, U WILL NEED TO TAKE IT TO THE NEAREST DEALER OR CUMMINS DIESEL REPAIR SHOP.
Posted on Jan 10, 2010
Marvin Thornbrue
  • 172 Answers
SOURCE: I have an Onan 2500 LP generator. What is the red knob for?
That knob should be to bring pressure up and down with 0 being off or the lowest range of the regulator. This regulator is adjustable for different applications apparently.
Posted on Jan 21, 2010
Anonymous
SOURCE: 96 cub cadet 2140 with cummins onan 14hp
I have cummins cub cadet Onan Elite 140 engine shuts off after about 20 min and won't restart for half hour.
Posted on Jun 06, 2010
The generator surges and stops while rv is in motion.
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Oct 05, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Onan propane generator starting problem
There can be numerous reasons why and is difficult to diagnose without more information. Assuming plugs filter etc are fine and new or clean and gapped. One thing I would check would be the LP pressure going into the unit, Then check the demand regualtor. You did not mention if it keeps running when it finally starts. Over time the demand regulator can accumulate a heavy wax preventing the diaphragm from opening. This wax is the result of a lubricate LP gas companies have in the gas. It can make starting harder, then result in it not starting at all. Regulators typically should be replaced and not serviced due to the high possibility of gas leaks. Hope this helps www.advanced-power-technologies.com
Aug 22, 2013 | Onan Cummins 3.6 KY-FA/26120 RV QG 3600 LP...
GETTING FAULT #36 ON CUMMINS ONAN MODEL#GSBB WHAT TO DO
Mar 19, 2013 | Onan Cummins A029J885 - Alternator Dryer...
Electric control circuit for onan 6.5 hgjab-1272
Mar 07, 2013 | Onan Cummins 6.5 HGJAB-1272 RV QG 6500 LP...
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
You say Guardian that is Generac???? Then you indicate Onan 4.0KY. If it is a Onan and it stops after you release the button there are a couple of things. 1 st check the brushes, and polish the rotor slip rings, check the resisitance of the rotor, the electrical harness plugs are tight. The control requires a voltage feedback while cranking to engage the PCB run circuits, if all those check out you have a bad control board.
Feb 15, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
8kw onan genset wont keep running whrn it tries to take on the load, will run forever if i kick the breaker switch to off.
What is the Spec number?
Also can you read a fault code on the start switch?
Do you know how to read the codes and post? if not let me know
Nov 17, 2012 | Onan Cummins 8.0 HDKAK/1046 RV QD 8000...
I need a manual for onan 6500 lp genset
You can buy a service and or operator manual from advanced-power-technologies.com
Aug 13, 2012 | Onan Cummins RV QG 6500 Generator, 6500W,...
I have a 6500 lp onan marquis generator in my rv. It starts then stops after 15 seconds or so. I did a code check on it using the manual and it read code 47. Controller not reading generator running. Any...
Jan 10, 2010 | Watts Onan Portable Generator - 5000 ,...
Electrical Supplies Logo
123 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
