SOURCE: 1999 GMC Suburban, K1500 4WD. Top brake light bar
third light is different circuit. saftey reason check fuses grounds wires
4 way flat molded connectors allow basic hookup for three lighting functions; right turn signal / stop light (green), left turn signal / stop light (yellow), taillight / license / side marker (brown) and a ground (white). so if you go down to 3 you will loose a function
4 way tow vehicle side.
4 way trailer side.
5 Way Systems
Same as 4 way system listed above but adds a extra blue wire for brake signal or auxiliary power. Used on pop up camper trailers or utility / boat trailers.
5 way tow vehicle side.
5 way trailer side.
6 Way System, Rectangle Plug
3/4 inch by 1 inch 6 way rectangle connectors right turn signal (green), left turn signal (yellow), taillight (brown), ground (white). The red and blue wire can be used for brake control or auxiliary. Use on a small motorcycle trailer, snowmobile trailer or utility trailer. Can also be used as custom wiring on trailers with 3 light/wire systems. See "Tow Vehicle Taillight Wiring" below.
6 way tow vehicle side.
6 way trailer side.
6 Way Systems, Round Plug
Round 1 1/4" diameter metal connector allows 1 or 2 additional wiring and lighting functions such as back up lights, auxiliary 12v power or electric brakes. Note: The black (sometimes red) 12v and blue electric brakes wire may need to be reversed to suit the trailer. Check with a test light or VOM. Uses: horse trailer, travel trailers, landscaping trailer, car trailer, etc.
6 way trailer side.
7 Way Systems
Round 2" diameter connector allows additional pin for auxiliary 12 volt power or backup lights. Uses: heavy duty landscaping trailer, car trailer, boat trailers, horse trailer, travel trailer, construction trailer, etc. Check with a test light or VOM.
7 way RV flat blade tow vehicle side.
7 way RV flat blade trailer side.
