SOURCE: Need to find Electronic range control part for my GE Range
http://www.myapstore.com/Omega/Dispatcher?REQUEST=ACCESSORY
After you go to this site it is going to ask you to pick your model number it is JTP56XXXX you can located the rest of the model number and from there you can order the part. Or you can just contact them via phone or internet. But you can order the part right offline
SOURCE: The oven controls are not working. then FO shows
If your appliance is newer than 1996 F0 error
code is a stuck key pad .
To verify turn off power and access the
control panel and remove the ribbon connector that goes from key pad to
control board .
Now restore power.
If the F0 code goes away you'll have
to replace the key pad .
If it stays it means the control board is bad.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: FO code of Kenmore double oven. Replaced control
Hi DGfoster,
What you can do , is try unplugging the oven for around 15 - 20 minutes and then check if the problem persists, if it does then what you need to do is replace the control panel , but first check if your oven is under warranty so that you don't have to spend much money.
So yes that means you can go ahead and replace the defective control panel.
Hope this helps ..:) Let me know in case you have any queries.
