Question about Philips Televison & Video
I have just brought a philips universal remote for a pal sonic tv tried all the codes didn't work did it by auto worked but all the buttons are back to front remote model srp3011 tv model tftv684led
Posted by Jerod Bolch on
5 Related Answers
AvioriX
ExpressFiX
  • 689 Answers
SOURCE: philips universal remote code for direct tv.
I have a code table for you, you may try this if its different than yours. Here is the direct link (You need Adobe Reader to open it)
Good Luck
Posted on Dec 29, 2007
Anonymous
  • 97 Answers
SOURCE: philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jul 29, 2008
rgeisler
SOURCE: I need a Universal Remote code for this model.
I got it to work with code 12002. I have the Comcast DVR Remote.
Posted on Dec 01, 2008
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: need universal code for philips sru3004 universal remote
here are some sites with your code.
www.remote-codes.com
www.tvcodes.com
www.universal-remote.net/philipsmagnavox.html
Posted on Apr 15, 2009
Anonymous
  • 563 Answers
SOURCE: philips universal remote not working for my coby dvd 224
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Traditionally, universal remotes do not work with COBY dvd players. The fact that you've found one that works at all is surprising. There isn't a true solution to your problem, however, because Philips created the coding for that remote without any input from COBY. The only thing you can try is a different COBY code if there is one in the code section of the book that came with your Philips remote.
While this solution doesn't "fix" your problem, I hope that by giving you the facts, I've enabled you to make an informed decision as to what to do next.
Please let me know if I can assist you further.
Posted on Apr 17, 2009
1helpful
AWA 16" LCD TV
Need different universal remote
1helpful
Lost the remote to my philips HTL2101A and it has no power button, so i can't use a programmable remote.
It should still be possible to use a universal remote to power on your TV.
Some universal remote instructions will say that the device has to be turned on in order to properly program the remote. This is not necessarily true, and you should still be able to use the universal remote to find a preset that will at least turn your TV on so you can then follow the instructions for the remote to find the exact preset that will work with every button on the remote.
First, look in the instruction booklet of the universal remote for the section of preset codes. It should be a huge list of 3-5 digit numbers with corresponding device names. There should be at least one or several for Philips devices. Find the code that matches your device.
Then, follow the instructions to program in that code. Should be something like: Hold down a certain button until the light on the remote blinks. Enter the code. Press another button to program the remote for that code. Keep in mind every universal remote is different and will have different steps to follow, but all generally work the same way.
At this point you'll want to just try the POWER button on the remote. If your TV turns on it means the code you entered is the correct code, or at least close to the right one. If it's not the exact correct code some of the other buttons won't work or will command your TV to do the wrong thing.
If your TV does not turn on with the first code you tried, you will need to program the remote with on of the other Philips codes. Just follow the same instructions you used to enter the first code and try another one from the list. Try the POWER button with each of the codes used until the TV turns on.
If none of the Philips codes work you will need to follow the universal remote's instructions to cycle through all of the codes (I have had to do this before). There should be another section of instructions that tell you how to do this. Again, try the POWER button for every code until the TV turns on. Once the TV is on, you will want to follow the instructions for the remote as normal to find the exact code preset that will work correctly with your TV.
If all else fails you might want to purchase a remote that is at least newer than the TV you are trying to operate because an older universal remote may not have the correct preset for a newer device.
I hope this helps! Good Luck!
2answers
I need the code to use a universal remote for a Soniq QV420PH 42" tv
Hello
Three digit univeral remote code for Sonic TV is: 014
Four digit universal remote code for Sonic TV is: 0014.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
OK.
The codes wont make tv work
The RCA universal remote rcr312w from wal mart will work (8.00)  Just follow the AUTO SCAN instructions.  Worked for me today!
2answers
Need codes for philips universal remote on a toshiba TV
i don,t know the code to this remote it is a ge universal remote
8helpful
5answers
39helpful
13answers
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
3helpful
9answers
Philips universal codes
If you dont have the codes for a philips universal remote you have to press code search and TV at the same time till the led light stays on. Then press the power button a few times untill the power turns your TV off, then press the OK button. After that the code should be in the remote.
Televison & Video Logo
Top Philips Televison & Video Experts
 Francisco Mauricio...
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
