Televison & Video Logo
Question about Panasonic Televison & Video
Hi. I have a Panasonic Viera Plasma TV that turned itself off and won't turn back on. When I try there is a click from inside the TV and the green light flashes rapidly.
When I try to turn it on there is a click from inside the TV and the green light flashes rapidly. There is then a second click and the red light flashes 7 times before pausing and then repeating the flashes. The model number is TX-P50ST30B
Posted by Richard Hardaker on
Panasonic tv won t turn on
Main board fault. Shorted component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
How to reset tv
hi Tracie,
is the set making a clicking noise?
is the power light flashing on the front?
or no power light at all just dead?
if the set is just dead, just put your ear to the back vents can you hear like a very faint screaming noise and can you smell and burning in the vent?
if so it just could be capacitors on the power board.
if its clicking the that will need a service kit on the power supply board.
if the power led is flashing then you will need to count how many flashers from start to finish when you first turn set on.
hope this helps.
Panasonic TH 42PX75 80 TH C42hD18 Dead TV Repair Fix TXN P1XGTUS HNTUS... Panasonic TV Won Turn On Learn How to Replace Your Power Supply FIX Panasonic Viera 42 inch Plasma SU BOARD TH 42PX75U Diagnosis Repair...
Hi My panasonic viera just turned itself off the
The flshing light could mean the power supply does not work correct. Can't deliver all voltages. But I can't get a service manual, so I can't tell you for sure.
2answers
Power surge tv won't turn back on
Check and replace its main power regulator board. Before replacing it, check the fuse, can be located on this board itself.
4helpful
Tv won't turn on!
Your problem post has not enough details to post a solution. Check this site named 'Electro-help'. so many faults to plasma TVs are there. Check it. Click this link, and select the site named above.
Hi, my daughter thought she was helping me clean by spraying my 1 year old 50 panasonic tv with 409 cleaner, it turned off and would not turn back on so i took it apart to let it dry out after a day i...
hi,
do one thing leave it for two three days at OFF condition and then try. when the time of cleaning chances for the solution go inside and creating some short circuits. give time to get dry itself
ok
My panasonic viera plasma tv is shutting off on its own
U WILL LAUGH, WHERE THE PLUG GOES INTO THE ACTUAL TV, NOT THE WALL, PUSH IT IN BETTER...I HAD EXACT PROBLEM AND CAME FROM 2 1/2 DAYS FROM GETTING NEW PLASMA!!! WHEEEW
374helpful
23answers
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Top Panasonic Televison & Video Experts
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
