Question about Frigidaire Refrigerators
How do i lower temperature on Frigidaire Gallery refrigerator
Posted by Denise Chandler on
Bill Boyd
    Top Expert:
  • Frigidaire Master
  • 53,816 Answers
The lower the numbers the lower the temp for a fridge
the higher the numbers the lower the temp for a freezer
as to lowering the already low settings
could be a problem thermostat , faulty door seals or compressor
call in a technician for a proper diagnosis
Posted on Jun 01, 2018
5 Related Answers
Anonymous
  • 109 Answers
SOURCE: Frozen food in fridge
Start with a total clean, vacuum and defrost. Unplug it before cleaning the motor compressor area. Make sure all the coils you can reach are clean. Plug it in and see what happens. If still the same - time to have a tech do pressure tests.
Posted on Mar 29, 2009
Doug Camburn
  • 122 Answers
SOURCE: 9-10 year old Frigidaire Gallery FRS26ZSH
might be your compressor relay gone bad. if the condenser fan was running and no compressor that could be the case. Also could be a bad compressor. you could try installing a 3in1 start kit. cost about $30. if doesn't start with that then compressor is kaput.
Posted on Jun 27, 2010
Robert Billyard
  • 277 Answers
SOURCE: Digital light is not working - cant tell
Replace the clock/digital display
Posted on Jul 25, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: refrigerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Frigidaire Gallery Model FRS26ZSHB3 The
There are two things that could be happning....
1. The control is bad and when you manually turn it it will close and start the unit, but it will not close after it opens to stop the unit on it's own....
In other words... you touching it and moving it will get it to work, but it will not turn the unit on if there is no outside influence on it....
The possibility is that the compressor will not restart when warm...but once it cools down it will restart....
I don't think this is what is happening though... my bet is with the thermostat/control...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Mar 12, 2011
Accidently entered incorrect code in temperature control pad and now the panel is frozen and registers 56 degrees on both fresh and frozen Frigidaire Gallery refrigerator FGHN2844LF2.
You have entered the control into "Sb," which is "Sabbath mode."
Hold the temp up and temp down buttons simultaneously for 5 seconds and the "56" should disappear...
Jul 18, 2016 | Frigidaire Refrigerators
Freezer works but refrigerator does not work roper
Good Afternoon Friend,
I understand that the freezer side is working, while the refrigerator side is not working properly, on your Frigidaire refrigerator, model# GLHS269ZDB. I suggest lowering the temperature in your refrigerator. You will need to wait 24 hours for the temperature to stabilize. If you are still noticing the refrigerator is warm, reset your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored, you will need to wait 24 hours for the temperatures to stabilize. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
-Best Regards-
WP
May 18, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerator condensation inside
Whether on the outside of the cabinet or the inside it is because you have warm moist air hitting the coldness of the refrigeration. It can also happen if you put hot food into the cabinet.
Also at the back of the inside of the cabinet there is often a small drain that empties the water from the defrost cycles. Check that they are clear.
Feb 02, 2018 | Frigidaire Refrigerators
FRS2625H - frigidaire gallery professional freezer is maintaining temperature but refrigerator is not - barely cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 30, 2011 | Frigidaire FRS26H5AS Side by Side...
Hello. I have a Frigidaire Gallery refrigerator. model is FRT22RGCW7 (which i can't find on this website). it was made in May '98. the refrigerator portion recently got exremely cold. freezer...
I used your model # and it came up on frig web sight . but they do not give age to these # only parts info . the age would only be avlb to dealers . i know this didn't ans your question but that info is not avilb. .. sorry mm
Oct 16, 2010 | Frigidaire Gallery Series® GLHT188WH Top...
9-10 year old Frigidaire Gallery FRS26ZSH refrigerator stopped cooling as only the fan was running and not the compressor. Cleaned the lower coil and fan of a small amount of dust. The unit worked for 1-2...
Jun 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
F3 error on frigidaire built in oven, cant cook
F3 INDICATES A TEMPERATURE PROBE FAULT.CHECK RESISTANCE OF PROBE,SHOLD BE 1100 OHMS
Nov 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidair Gallery fridge/freezer... Freezer is
change the control board in the rear lower left corner of unit part# 4334000 2 appliance parts pros
Oct 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
211 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
