Cars & Trucks Logo
joan maguire Posted on Jun 01, 2018
I have a Nissan Micra 09 reg.I put the code for my radio correctly but when I turn off the car and turn it back on the radio asks me to code in again can anyone help
1helpful
I recently bought as 09 Nissan Micra .I put the code in correctly but. When I turn off the car and turn it back the radio revert back to asking for the code again
Sounds to me like either someone has had it out and it is wired incorrectly, or possibly a blown fuse, but you are loosing KAP when the key is turned off.
2answers
How do I save the radio code once I put it in It is a MICRA 2015 build
You need to be certain you are entering the correct code in the correct way to avoid being permanently locked out of the radio.
Different territories and models have slightly differing radios and the coding sequence can vary slightly. The vehicle literature pack should either contain an audio manual or the details will be found in the vehicle handbook.
My nissan micra needed a new battery and now the radio wont work, i have the code but the number 2 button wont work can anyone help
You must have the radio repaired to enter the code, there is no way around the problem of the inoperable button. Next time use a battery back up, never completely power down the system. Walmart has these battery power supplies.
2answers
How to set clock on 2012 nissan micra radio
get correct manual from Nissan.
if stock radio,
the generic nissan, for 2011 will list all radios sold that year.
get one.
nissan dot com, its free.
online or at the parts counter.
Need radio code for nissan micra cant get radio out
Honda's have the code inside the drivers door frame. There is tire pressures and other data there as well.
My P Reg Nissan Micra wont start. It was working
Sounds like a fuel issue if you have run it dry, maybe a blocked fuel filter, or maybe it needs new spark plugs, check the air filter as well.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
