Model number is RUTG95DVP
SOURCE: rheem tankless water heater wont lite
the system was not sized properly, you need to have a 3/4 gas line to the unit for the volume of gas it needs, the tankless water heaters need to have every bit of gas that is says, it sounds like who ever installed di not make sure you had enough gas comming in the house, you might have to either have a new meter installed or run the gas lind directly from the meter to the water heater and cap off the gas line thats there
SOURCE: Rheem tankless water heater error A3 than flashes
diaphragm valve or micro switch best of luck
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
SOURCE: what is trouble code C8 on a rheem tankless water
c8 is a cycle not a code... the code comes up after it, may look like a temperature... 2 digiti numbetr
SOURCE: rheem gas tankless water heater with error code c4 13
problem is inside burner compartment o2 sensor dirty or block..need to have a qualify technician clean it.
