SOURCE: Philips GoGear SA3245 - Playlists
Open up Windows Media Player(WMP) on your
computer. To add a track to a playlist on your computer using WMP, click to
highlight an item.
Right-click on the
item that you want to add, then select Add to Playlist. A pop-up window will
appear. Select an existing playlist or add a new one. Your selection is now
added to your playlist.
Delete a track. When
you do not want a track on your playlists anymore, you are able to delete it.
To delete tracks and playlists, click to highlight an item. Right-click the
item and select Delete from Library to delete it.
To Edit track
information, click on a track. Right-click and select Edit. Click on the text
boxes to edit relevant information.
Once all changes have
been made, connect your GoGear to your computer with your USB cable and
download the new playlists.
SOURCE: charging battery
you might have a faulty charger or the battery just won't charge , if you can exchange it back at the store I would do that , but otherwise the charger would have to be tested and the battery , and if those are ok then something is wrong in the mp3 player
SOURCE: gogear says ok to disconnect, but isn't charging, how do i make it charge?
hi , enter to the website of philips and download the software and new firmware select first you exact model, next quit batteries of your mp3/mp4 player and press the button (bent arrow) all the time until it detects and connect to the computer and run software and choose repair
SOURCE: Lost CD software for philips gogear SA3245/37
i have the cd and i can make you a copy because you need it because the mp3/mp4 have a special format to use to put into the mp3/mp4 but any ways i will give you a copy for 6 dollars plus shipping and handling if you need it email me at [email protected]
SOURCE: My philips gogear 8gb won't come on.
DO U HAVE A WINDOWS XP IT WONT EXCEPT IT IF ITS LOWER THAN WINDOWS VISTA SO I DONT KNOW WHT TO DO IN UR PREDICIMENT
