Televison & Video Logo
K
Kevin Posted on Jun 01, 2018
I have a Polaroid TV and my sky Q turns the TV off but not on. I would also like my sky q remote to control my Phillips Sound bar? Can you help?
5 Related Answers
Anonymous
  • 372 Answers
  • Posted on Jan 20, 2008
SOURCE: Tv wont switch to Sky when remote control is pressed
Hi.
On the sky box do the following.
Check scart to tv is in the correct socket marked TV.
Try pressing services
then system setup
then picture settings.
Then try switching scart control to on or off.
If this sorts it great. If it doesnt check scart lead has all pins wired & not only A few.
http://dysonmanuals.llc.nu
Chris..
Anonymous
  • Posted on Dec 04, 2008
SOURCE: Remote control code Tevion TV
Goto. www.medion.co.uk - pick support, enter model number 83388 and you'll get access to the manual
Anonymous
  • Posted on Jan 07, 2009
SOURCE: setting up 42lg3000 with sky
i have same tv, this i was i did on mine. on the sky+ remote push tv and then press select + red button at the same time, the red light blinks twice, then push 1174 then power button.
Anonymous
  • Posted on Mar 14, 2009
SOURCE: SKY remote control programming
I used 0081 for the KENMARK LVD160 and it worked straightaway. This was for a REV 6 - SKY remote.
Anonymous
  • 27 Answers
  • Posted on Apr 04, 2009
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
I need the code for polaroid tv with asda remote control model no:urc20-d1f
I just bought a Polaroid 22 inch LCD DVD Combi,, I struggled for hours trying to find a code online,, and eventually researched that my Polaroid TV is made by Phillips,, I entered a Phillips 4 digit code (0081) and it worked.. I also found this link very helpful,, I used the 4 digit code routine. http://www.rtv.co.uk/remote_codes_for_sky_dig_remote.htm
1helpful
2answers
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Polaroid tlu01911cu remote code
I have one like this and found out its code is 0486 as a TV on a Silvercrest programmable remote
1helpful
Sky remote code
You will need to go to Sky's website and order a new remote if this doesn't work.
Press tv on the remote
press and hold Select and red until the remote LED blinks twice
type in 0 0 6 0
press power button on the remote, if the tv goes off press select and it should control all the tv functions.
if the tv does not go off press tv then power buttons on the remote and keep doing this until the tv goes off, then press select once the tv goes off.
Like I said earlier, if this doesn't work you will need to order a new/replacement remote via Sky's website then put the code listed above in.
Sky remote do not work wit polaroid tv 3232
I own a One-for-All universal remote (model URC-4220), and my booklet says the setup code for a Polaroid TV is 0765.
Hope this suggestion, helps you out. Please take a moment to rate this info, by using the rating system below. Thanks.
6helpful
2answers
2answers
Remote control problem
Have you tried "One for All" universal remotes?
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
