Question about Samsung Heating & Cooling
How to solve the problem of my SAMSUNG SPLIT AC BORACAY 2x internal fan is always out of order?
Posted by Jimmy Almendares on
3 Related Answers
Anonymous
  • 614 Answers
SOURCE: Water leakage from internal unit of split AC
Draim pans do get dirty and partialy block drain pan. If possible take a shop vac and gently **** out the drain line. This will pull the restriction out of the line and help clean drain pan. Rusty
Posted on Jun 07, 2009
Anonymous
  • 9 Answers
SOURCE: Hi I have 1.5 ton samsung split AC. the problem is...
the water comes from the coil, start there make sure there is no obstruction coming out to your condensate line and make sure its properly pitched.
Posted on May 22, 2010
SOURCE: Inverter AC model RAC60NHA Problem -
Check the outdoor units electrical service disconnect at the outdoor unit, it may have a removable plug with time delay fuses inn the plug or behind a plastic wall facade or divider, you can remove this exposing the fuses if not in the plug itself,it may have a breaker there too? whatever is there insure its on and fuses are good, the main breaker panel for your home may be off too!
Posted on Dec 27, 2010
Split AC whole unit turnig off at each compressor start up!
Dirty coil wash outside unit with water and change indoor unit filter
Jun 08, 2017 | Heating & Cooling
Hi I have 1.5 ton samsung split ac. The problem is to solve the water leakage in the indoor unit. Kindly advise
May 19, 2010 | Samsung AS1293L Air Conditioner
How to put background picture?
Your request is not clear Boracay? is this a place or some software program. What are you trying to put the background in?
please rate my help++++Thanks for using FIXYA
May 07, 2010 | Adobe Photoshop 7.0 for PC
SAMSUNG split AC AS09WHWE led keeps blinking.
Samsung Air Conditioners SAMSUNG split AC AS09WHWE led keeps blinking
Sep 02, 2009 | Samsung Heating & Cooling
Samsung 1.5 ton slpit AC.the out door unit is very noisy
Check to see if the noise is coming from the fan, could be bad bearings. Replace the fan motor if that is the case. If the noise is coming from the compressor, the only other place besides the fan, then your compressor has some issues and will probably stop working soon, maybe line up for a replacement before you are left with a hot house.
Jun 11, 2009 | Fujitsu 24C1 Air Conditioner
Jun 05, 2009 | Heating & Cooling
Soleus KFGHP-09-ID Mini Split
This is normal operation for these styles of minisplits. The thermostat is not in the remote but is located on the return air of the indoor coil, so the air needs to be flowing in order for the thermostat to measure the rooms temperature. Set your fan speed to auto and the fan will slow down when setpoint tempurature is met.
Phil Hodges,
Tech support Soleusair
May 18, 2008 | Soleus KFS18GW 18,000 BTU Heat & Cool 230V...
AC complaint
You need tor replace the internal fan, it may be stuck up or weak running capacitor for internal fan.
Apr 08, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
37 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
