SOURCE: Is there an update for the epson 1650 smart panel?
Just log on to the EPSON website and there you can download the latest software for your gadget/s
SOURCE: Bios update disaster
You have to download the old bios with another PC and then flash your bios with that.
Use this list to find your bios download depending on your video chip.
Worldvet
SOURCE: Wireless working very slow
Hey there
You are not getting this problem due to any BIOS and wireless driver.
as you said that you are not getting any problem with your another system.
Checkout for the range you are working in. else it wont be that much effective.
Sometimes it happens that your driver misplaced or changes its parametetr in registry without awaring you.
So first repair your wireless network
else secondly repair ur XP PRO.
this will surely help you to have a good speed with ur network.
Gimme your acknowledge
Thanx.
Romy
SOURCE: Dell 630M
Yes. Purchasing a Vista install disc is exactly what you need to do. Install Vista from the disc, then go to the link bellow, download any needed drivers, and you're good to go.
SOURCE: Trying to upgrade H/D on IBM T43 laptop, get 2010 error on
Error code 2010 is definitely hard drive problem.
Did you get the firmware from the site below?
Link to hardware maintenance manual for reference:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t2393.pdf
Here's the fix straight from the maintenance manual:
If in the primary bay the customer is using a non-IBM or non-Lenovo hard disk drive (HDD), or an old generation IBM HDD which is not supported by this system, with the risk in mind, the customer can still use it by pressing ESC. If in the primary drive bay the customer is using a supported IBM/Lenovo HDD with an old firmware, the customer needs to update its firmware to the latest. The latest version is available at http://www.lenovo.com/think/ support
