SOURCE: TV does not respond to Remote
Dear Mr.yeye,
There seems to be a problem with the IR LED of your television. solder the connections if any of them is cut. Also there can be loose connections. its better to contact the retailer from whom you purchased this tv
SOURCE: need remote control code for 32" X2GEN tv
Good luck. I have the same issue. No codes are available for the X2Gen. To make matters worse, it appears to use a non-standard frequency for the carrier signal, maening that other remotes won't work with the TV.
I purchased a learning remote, thinking I would just "teach" it the codes directly from the X2Gen TV remote. This didn't work either.
There appears to be no way to use any remote other than the one supplied with the TV. Whatever you do, don't lose it!
SOURCE: Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
