Question about Point Computers & Internet
Je vais une vr 360
Je vais point
5 Related Answers
Anonymous
  • 90 Answers
SOURCE: une image plus claire S.V.P
Please call Jazz Products @ 732-572-7050
Posted on Jun 30, 2008
Anonymous
  • 94 Answers
SOURCE: flash disk 2G type kingston
are u gujju
just format and get it done
Posted on Aug 12, 2008
gremlin11
gremlin11
  • 78 Answers
SOURCE: epson acculaser c1100 service req E521
the developer home position sensor is not registering. it will need to be cleaned. This will involve the removal of the left side cover, the removal of the power supply pcb and the removal of the sensor which sits under the power supply. clean the sensor out with a dry pain brush and re install. be careful to turn the printer off and unplug it prior to removing any covers. the cover is easily removed, however, take your time and make sure you release all the clips on the inside of the cover. once the cover is off it is easy to get to the sensor. don't worry too much about all the connections to the power supply, they only fit in one plug and cannot be inter changed.
Remember to take your time in this operation. If you are at all uncomfortable with this, do yourself a favor and call a technician in to do it. He wii do it in about fifteen minutes.
Gremlin11
Posted on Dec 10, 2008
fanaudi
fanaudi
  • 1381 Answers
SOURCE: BONJOUR JE POSSEDE UNE IMPRIMANTE
Bonjour cevale358 ,
Il n' y a malheureusement pas d' autre solution que de rentrer l' imprimante chez Samsung pour r?paration . Il s' agirait malheureusement d' une panne assez courante sur ce mod?le qui concerne le fusible et l' unit? d' alimantation .. Voici quelques pr?cisions si tu comprends l' anglais ... http://www.fixyourownprinter.com/forums/printer/66821
Cordialement ,
fanaudi .
Posted on Aug 27, 2011
Bonjour j’ai une Combi dX mod?le 502 donc je vais vous faire parvenir une photo et je me demande si vous les racheter Merci de me r?pondre
Hello I have a Combi dX 502 model so I will send you a photo and I wonder if you buy them back Thank you for replying
https://translate.google.com
No, FIXYA does not buy or sell sewing machines.
Slt est ce quon peut avoir des fractions sur la calculatrice je suis nouvelle sur son utilisation en plus jy conai riien pour le moment et en octobre jdoi faire la 1ere jsuis du senegal jveux que vous...
Bien que je n'appr?cie pas de lire un texte en charabia, je vais essayer de r?pondre ? ta question.
Si tu as une touche MATH, appuie dessus. Tu devrais voir alors une liste de commandes parmi lesquelles figure une t?te de fl?che ?paisse devant FRAC. Saisis ta fraction, appuie sur MATH puis s?lectionne la commande >Frac. Appuie sur ENTER. Le r?sultat sera LA fraction r?duite ?quivalente.
Si tu veux convertir une fraction en sa repr?sentation d?cimale fais la m?me chose que ci-dessus mais s?lectionne >DEC.
Bonjour, j'ai tenté de me
could you talk in [ENGLISH] please?
I have the OPCFASIL problem on a Philips CDR 760. Tried many disks, gave up. Does anyone want this unit? Free. Just pay for shipping.
ma platine laser philips 760 elle dit qu'il n'y a pas de disque puis elle annonce le total des disques j'appuie sur le premier elle ne d?marre pas g achet? une 775 d'occasion je vais br?l? un cierge ...
5helpful
I want the eurovox codes for 5a01 ....can any1 plzz help????
bonjour jaimerais bien savoir jai un viewsat 2000 ultra et jai fait mes mise a jour et jai les poste de radio et de chaine sauf il m afiche le signe $ et crypter et jai une coupole de bel allor comment avoir une cle ou un code pour avoir les chaine merci beaucoup et je vais attendre votre reponse ah aussi pourier vous me l ecrire en francais car je ne lie pas en anglais
2answers
Bonjour ou se trouve le reste sur ce modele?? j'ai DEG de programme dessus et je ne suis pas capable de l'enlever. merci
écoute, ne te fâche pas : je ne comprends pas le sens de ta question et je devrais m'abstenir de te venir en aide, craignant d'interpréter incorrectement ton problème (et ce n'est pas ma maîtrise de la langue de Molière qui est en faute!!) Mais je vais quand même essayer de t'aider.
L'indicateur DEG que tu sembles vouloir éradiquer est parfaitement inoffensif. It est affiché sur l'écran pour te rappeler que l'unité d'angle est le degré. Cela signifie que tout argument que tu fournis à une fonction trigonométrique (sinus, cosinus, tangente, cotangente) est interprété comme une valeur en degrés. Donc si tu calcules sin(Pi) ne t'attends pas à obtenir 0 mais le sinus de 3,14.. degrés.
De même, toute valeur retournée par une fonction trigonométrique inverse ( arc sinus, arc cosinus, arc tangente, arc cotangente) sera en degrés.
Si tu changes l'unité d'angle de degré à radian, l'indicateur RAD sera affiché quelque part sur l'écran. Donc je te suggère de ne pas t'acharner à faire disparaître cet indicateur: Il ne fait que te monter quell unité d'angle tes calculs utilisent. C'est plutôt commode, ne trouves-tu pas?
Maintenant, si tu veux préciser ce qu'est ce reste que tu cherches, peut-être pourrais-je t'aider? Tu n'as qu'à faire un commentaire et je verrai ce que je peux faire.
1helpful
Je n'ai plus de tonalité quand je téléphone, plus de son
Mouais, il manque un peu d'info pour vraiment cibler le probleme mais je vais commencer par y aller avec le plus simple et évident, et si ce n'est pas le problème, récris un commentaire pour préciser pas de son dans quel sens. Donc, tout simplement a priori comme ca, je dirais que le haut-parleur de ton tréo est brisé, ou encore qu'un des connections ou soudures qui le relient a la carte principale du tréo a cédé. Si tu es sur que ce n'est pas ton cas, alors faudrait que tu précises si t'as juste aucune sonnerie mas que tu entends quand meme quelques sons quand par exemple tu fais jouer un MP3 ou quelquechose. Ou encore si vraiment tu n'entends pas parler la personne quand elle décroche mais que tu entends ta sonnerie quand quelqu'un t'appelle. Bref, essaye d'etre le plus précis possible et de me dire tous les modes ou le son fonctionne ou fonctionne pas. Voila, donc en espérant t'avoir un peu aider, sinon j'attends de tes nouvelles pour pouvoir essayer de mieux comprendre le probleme et te trouver une solution.
Need plastic handle on Rival Crockpot lid.
J'aie un crok pot Bravetti de 7 pintes, c'est une petite merveille jusqu'à aujourd'hui car une de mes poignées s'est cassée lors de son utilisation. Je ne l'aie pas cognée, j'aie seulement pris mon crock pot ( qui était en pleine cuisson depuis 4 h00) par les deux poignées pour le changer de place sur mon comptoir de cuisine et crack, la poignée m'est resté dans les mains. Je n'ose pas imaginer ce qui aurait put arriver si il y avait eue un enfant près de moi lors du déplacement de mon crock pot Bravetti 7 pintes en inox. J'aurrais pu brulé quelqu'un pour le reste de sa vie....ATTENTION lors du déplacement de votre crock pot car les poignées ne sont pas solide du tout, je suis vraiment décue car j'adorais utiliser mon crock pot mais à partir de maintenant.....je vais y penser à deux fois avant de m'en procurer un autre Bravetti 7 pintes en inox.
Lyne
Abitibi
Computers & Internet Logo
Top Point Computers & Internet Experts
john h
ADMIN Canada
ADMIN Canada
ray gallant
Are you a Point Computer and Internet Expert? Answer questions, earn points and help others
