Question about Ricoh Office Equipment & Supplies
Can i use my Ricoh aficio morgen 4002 without hdd?
Posted by Phil on
OfficeServiceAjnc
  • Ricoh Expert
  • 215 Answers
No. I think you can use it just for copy mode and even in copy mode will make just one copy no multiple copy. No scanner and printer function is working without HDD. But you replace the HDD wit a ordinary HDD from a PC. the procedure is easy for a person with small technical skills, plus I can give point to point instruction how to replace it and make it work.
Posted on Jun 26, 2018
5 Related Answers
Anonymous
  • 82 Answers
SOURCE: how do you set a scanned document folder on a ricoh aficio 1045?
do you mean how do you creat a folder to scan your documents into ? if you have document server or scanner buttons on the key pad, then just select scan and mofidy the folder to your choosing.
Thank You,
Mikey
Posted on Apr 06, 2008
Anonymous
SOURCE: ricoh copier aficio 401 error sc 419
How do i clear SC 548 error on aficio 1022 copier machine
Posted on Jul 09, 2008
Anonymous
  • 86 Answers
SOURCE: driver for Ricoh Aficio SP-C210SF
Please browse the link below;
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=11342&ricohmodelid=6317&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fspc210%2Fspc210en%2Ehtm
Good luck and please rate me, thanks.
Posted on Jan 29, 2009
quennie732
  • 422 Answers
SOURCE: Ricoh Aficio 2018D
This could be a very bad code its "main motor lock", either you have too much load on the drive unit ( paper stuck, locked up pcu or fuser ) and maybe bad BICU board.
-Carl, please let me know if this helps.
Posted on Jun 27, 2009
Anonymous
SOURCE: I Cannot solve SC541 Error in RICOH Aficio 270
It's not the PCU (photoCONDUCTOR unit), It's either a thermistor or blown out heater lamp in the fuser. Call a tech. The code can only be reset in service mode
Posted on Aug 12, 2010
2answers
J'ai une ricoh mp c5501qu iaffiche sc819
North American website, we speak English :>)
I have a ricoh mp c5501 which displays sc819
Google Translate ici.
https://translate.google.ca/?sl=auto&tl=en&text=J%27ai%20une%20ricoh%20mp%20c5501qu%20iaffiche%20sc819&op=translate
The answer is NOT good!
AFICIO MP C551 SC 819 ( 5348 0x5554444F ) - Copytechnet
https://www.copytechnet.com > forums > 126200-aficio...
Jan. 13, 2018 - SC 819 is a fatal kernel error. Either the controller and possibly other boards were blown by the power surge or the components you replaced on ...
Ricoh Aficio 2035 SC819 Error Code - Copytechnet
Mar. 31, 2010
Error Code Ricoh MP5002 SC 819-00 - Copytechnet.com
Apr. 13, 2016
Error Code SC-819 MP 5000 - Copytechnet.com
Oct. 4, 2013
Thread: error SC 819 - Copytechnet.com
Mar. 30, 2017
More results from www.copytechnet.com
SOLVED: What is sc819 for ricoh aficio c4501 - Fixya
https://www.fixya.com > ... > Ricoh
Sep. 1, 2019 - Yeah most likely the Hard Drive, just replace them with off the shelf ones. Could also be the dimms, controller, nvram or firmware. I would unplug the HDD first ...
SOLVED: My machine ricoh mp c2352sp displays SC 819. I
Nov. 18, 2019
SOLVED: My ricoh aficio is showing sc819 - Fixya
Jan. 24, 2018
Ricoh mp 2550 error code sc 819 how to solve this problem
Nov. 21, 2019
SOLVED: Sc819 trouble/error in ricoh aficio mp5000. any - Fixya
Jun. 2, 2011
More results from www.fixya.com
Ricoh Aficio 480W - SC819 - PrintCopy .info
https://printcopy.info > brand=Ricoh > code=SC819
Ricoh Aficio 480W · Code: SC819 · Description: Fatal kernel error. Due to a control error, a RAM overflow occurred during system processing. One of the following ...
2answers
How to installe new hdd to ricoh mp 1100
Hi there, I found a guide on how to replace the hard drive on a similar Ricoh MP model - https://www.manualslib.com/manual/477825/Ricoh-Aficio-Sp-4410sf.html?page=41
I hope this helps!
1helpful
Ricoh aficio 3228c error sc 873
Thats a hard drive error. Initialize SP5-832-008 or replace the HDD! Most machines use a simple IDE HDD. Just open the machine at the back, youll see the HDD
Brand Aficio 3030 and mpc5000 cannot get into service mode once error 672 is displayed. the only way was to replace the main controller if there any other ways to settle this error 672
I think that the problem is with the HDD. Did you try to remove the HDD? Try to un-plug it and turn machine ON. If it works you just need to format and recover the HDD. Or replace it with a new one
5helpful
3answers
RICOH Aficio copier is giving error code SC320, what is the problem?
i have a ricoh aficio 450 copier.it pick the paper from the tray and after afew seconds the paper will come without coping.(plain paper)
Ricoh af2027 please wait with a wrench no code
Hi that normaly indicates the there is something wrong with the HDD. open the back of the machine and unplug the HDD. Swith the machine on. If it turns on the HDD is faulty. The machine will work without the HDD but you will not be able to use the doc server. To fix the HDD plug it in to a PC and initilize it. (right click my computer, manage, disk management, right click on drive, initilize. Put it back in the machine.) Should solve the problem.
1helpful
I have ricoh 1035 & eror sc990. without hdd ,i can print and copy one side and by hdd i have error. i do . & # toghter for 10 second for soft reset and nothing happend. in code menu: 5801 - 2109 -...
If you use Katun OPC drum in your machine and is work more 80000 copies you need to replace the OPC drum and the drum cleaning blade.After replace the drum perform the process comtrol and the SC990 disipaire.Whenever use other genuine parts and not original Ricoh parts appair SC codes to refer HDD parts.100% this method is working.
2helpful
5answers
Ricoh aficio 1045 error e990 please help it
Error 990 can be cuased by many things. Most of the time it is related to the Hard Drive. you could try replacing it.
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
