SOURCE: i need ricoh aficio mp 1600le driver, how do i get into.
Here is the driver page:
http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/mp16/mp16en.htm
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: how to print envelopes aficio ricio mp c4500
On an MP-C4500, envelopes must be printed using the bypass tray (the fold-out tray on the right hand side). Put the envelope in face-down and tighten the two fences so the envelope is snug.
When printing the envelope, make sure the print driver is set for the correct envelope size. If envelopes tend to jam in the printer, try setting the bypass paper type for thick paper.
SOURCE: how to install ricoh aficio
if you have user manual read it
do you have driver cd?
In most cases you will find that the Windows drivers found here are
"self-extracting" (.exe) archives. Click the desired file. When
prompted, we recommend setting the destination to your desktop. Create
a new folder and move the archive into it. Click the file, it will then
extract the software and related files inside of your new folder
automatically. Alternately you may extract or move these files to a
floppy disk. Please note that these files will only self-extract if
executed from Windows.
After extracting the files to a disk or a special directory, you
should look for the installation program which is usually called
"setup.exe" or "install.exe", click it to begin installation. If
neither of these files are present, you should look for a text file
containing special instructions called "Readme.txt" or something
similar.
Sometimes there is no installation program because you must install
your driver via the Windows "Add Printer" function. Instructions for
installing printers can be found in the Windows help file.
Our Macintosh Archives are also self-extracting archives. These
files should be downloaded and then executed. The installer will be
present on the desktop when done. Click the installer and follow the
instructions to install.
Types of Printer Drivers:
