Question about Apple iPod MA446LL/A MP3 Player
IPOD STUCK MY IPOD IS STUCK ON THE MENU SCREEN. HELP!!!!
Posted by REDDOGBRD333 on
  • Mary Hurley Lawson Dec 13, 2007
    my Ipod nano is stuck on ok to disconnect...it won't do anything. help
  • Anonymous Feb 13, 2008
    ipod is stuck on the menu screen. already tried pressing menu and center button at the same time and that does not work. please email me a solution if there is one at [email protected] thanks,
Anonymous
Thankz so much
Posted on Apr 26, 2008
Anonymous
THANK YOU!!!!!!!!!
Posted on Jan 04, 2008
3 Related Answers
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: ipod nano not responding
http://serviceman.site88.net/index_files/Apple_Ipod.htm
Posted on Aug 05, 2008
SOURCE: stuck on white screen reading accessorize test
Have you tried resetting it? Press and hold the setting and menu buttons at the same time for about 6 seconds.
Posted on Mar 13, 2009
mneilsen2084
Mel Neilsen
  • 342 Answers
SOURCE: My iPod 160 GB Classic is stuck with just Apple
Try forcing the iPod into disc mode to restore.
Putting ipod into disc mode http://support.apple.com/kb/HT1363 Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.) Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect" If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
If this does not make the iPod connect to your computer, I would suggest checking out www.rapidrepair.com for further ideas and options to your issue.
Posted on Jun 22, 2009
Unfreezing ipod otuch 2nd generation
Hi linda_wat834
When the Apple Logo is stuck
If this happens, put the iPod into Disk Mode through the diagnostic menu. Then connect the iPod to your computer and update or restore the iPod.
Sometimes you can get away with just updating the iPod, so try that first, but usually you have to restore the iPod .
As always make backups of your music files, because the restore procedure will eliminate them.
Please take time to rate me
Bud
Apr 03, 2013 | Apple iPod touch Second Gen (8 GB,...
My Ipod wasn't working for awhile, but now I got it on again. I have it plugged in my computer and Itunes is telling me that I have too put my password in so they can connect to my Ipod, but my Ipod won't...
Try putting the ipod into disk mode, when doing this the ipod will act as a separate hard drive. In doing this you should be able to restore or repair the ipod. Repairing or restoring your ipod should resolve the issue.
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
May 03, 2011 | Audio Players & Recorders
Ipod is stuck on a track screen stuck no responsewont do anything
Hold the center button and the menu button down for 10 seconds to force the iPod to shut down. It should work after this
Feb 28, 2011 | Apple iPod nano 3rd Generation
My apple classic is stuked how to retrive this
if you ipod is frozen or stuck on one screen you can reset the ipod by holding the menu and center button at the same time-
the ipod will reboot and go back to the main menu
Nov 08, 2009 | Apple iPod classic MP3 Player
Ipod is stuck on the language screen. Scroll
push center and menu button same time
Jul 25, 2009 | Apple iPod nano
Stuck on white screen reading accessorize test
Mar 12, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod nano 8GB 3rd generation FROZEN!
You need to reset your ipod. Flip the hold switch on then off, then press select button and menu button at same time. Hold for 10 seconds or so. Ipod should shut off and reboot to apple screen. If this doesn't work first time try again. This should solve any stuck screen problems. Mine was stuck on pioneer screen and this operation fixed it.
Aug 09, 2008 | Apple IPod nano Second Generation MP3...
My Ipod is frozen
OK what you need to do is reset it. To do this you will need to hold down the menu and select buttons simultaneously for approx 6 seconds until the apple logo appears on the screen. This should reset and un freeze your ipod.
Try this and let me know how you get on.
May 12, 2008 | Apple Mini IPod
Hanged apple ipod classic
Stuck or frozen
you have to hold the the menu and middle ong for 10-20-30 secs
hold the menu +center button and it will turn off and reset
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Feb 24, 2008 | Apple iPod MA446LL/A MP3 Player
My Ipod is stuck on the menu screen and will not play any music. It won't turn off, None of the buttons respond. Any Ideas
Try pressing the MENU and the Center button together for a couple of seconds. This restarts the ipod.
Hope it works.
Nov 25, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
41 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
