Question about Medion Computers & Internet
SOURCE: File header checksum does not match computed one. ???
You have one or more critical corrupted file/s which prevents the laptop from booting up.
To get the laptop operating again, you need to insert the Windows Vista CD and do a Repair and if this fails you need to install Vista again.
Posted on May 05, 2009
SOURCE: I am gettin a blue screen that says Stop c00000221
If you've encounter with this issue, this issue the same with your BIOS password you can easy access the BIOS by reset the CMOS battery and jamper.
The checksum error refer in CMOS memory that is maintained while the PC is powered off by
a small battery, which is attached to the motherboard. If you remove
this battery, all CMOS information (including the BIOS password) will
be lost. You will need to re-enter the correct CMOS setup information
to use the machine. The machines owner or user will most likely be
alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard,
making it difficult to remove. If this is the case, you have another
alternative. Somewhere on the motherboard you should find a jumper that
will clear the BIOS. If you have the motherboard
documentation, you will know where that jumper is.
If not, the jumper
may be labeled on the motherboard. If you are not fortunate enough for
either of these to be the case, you may be able to guess which jumper
is the correct jumper. This jumper is usually standing alone near the
battery. If you cannot locate this jumper, you might short both of the
points where the battery connects to the motherboard.
Posted on Dec 10, 2009
SOURCE: toshiba, the file is possibly corrupt. the file header checksum d
Use reginout regcleaner to fix ur problem
Posted on Aug 19, 2010
SOURCE: file is corrupt. the file header checksum does not
The file is damaged and cannot be accessed. If the file is on the hard disk, then a fresh/new copy needs to be copied onto the hard disk.
