SOURCE: Replacement part
I had a broken handle with this grill, and called Fox International @ 1800-231-9786. I asked while speaking to them about replacing my drip pan, and they do carry it. It cost $14.95.
SOURCE: my 2 ton ac with air won't run even the fan on
Hi; Does Your air handler have a small fuse on the circuit board. CHECK IT. What kind of heat do You have / heatpump/gas/total electric/. Need more info...alpharome416
SOURCE: i have an older model heil quaker natural gas
Test to make sure the limit switch is still working prior to the rewire. Use an Ohm meter and test for continuity. If good, use some good quality 14 or 12 guage wire to rewire. If the unit has an in-line fuse, you will need to replace that as well.
SOURCE: Where can I find a drip pan to put under my AC unit?
Did you look at the homedpo thay shod have one
Probably your flue isn't clear enough.
Try blowing it out, you might have to remove a cover to do it.
Otherwise it may be the flue passage detector needs replacing.
Here is a tip that will help you try to figure out why your furnace is not working.
Basic Furnace or Heating System Troubleshooting
heatman101
