Irons Logo
S
Steve Storck Posted on May 30, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am looking for a replacement cord, part # RS-DE245954 but Rowenta no longer manufactures it. Is there another cord that will work with my Rowenta DM911 iron?
Marvin
Level 3:
Top Expert:
  • Rowenta Master 85,242 Answers
  • Posted on May 30, 2018
Marvin
Rowenta Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024396
Points
266281
Sorry we do not have any parts locator service here.
5 Related Answers
A
Anonymous
  • Posted on Jul 31, 2008
SOURCE: rowenta dx6700
The wire inside the cord is likely torn ant it connects and disconnects as it is moved back and forth. This happened to me too. I just need to find where to get a new cord.
Anonymous
  • 18 Answers
  • Posted on Mar 06, 2009
SOURCE: Rowenta DX-8800 will not heat. Location of heating element?
The heating element is incorporated in the base. Rarely is the heating element bad. Its usually a connection or control problem. You cannot just replace the heating element.
Anonymous
  • Posted on Jul 06, 2009
SOURCE: Rowenta Iron
Special screw called "Torx tamper proof" call 925 8271011 and order "Rowenta tool" $10.00 plus shipping-this place also sells Rowenta parts
David Shaub
  • 2994 Answers
  • Posted on Oct 06, 2009
SOURCE: Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Anonymous
  • Posted on Sep 26, 2010
SOURCE: wiring diagram for Rowenta DE-05
I took the iron apart for cleaning and installing a new cord and neglected to note which wire goes where. Does anyone have a wiring diagram for this iron?
Replace chord support sleeve
I think you need to open the back and disconnect the two wires inside. Actually I am looking for that cord sleeve. Where did you find it. I've found a complete assembly for this (Rowenta RS-DX002754)
which is available on line, but all I need is the sleeve.
Good Luck
Iron heating sporadically and sensor lights working sporadically
It looks like the cord has a loose connection and will need to be replace.
Iron cuts off in the middle of ironing
It is probably an intermittent cord connection next to the strain relief. You can simply remove the back cover, cut the cord, pull the remaining cord (approx 6-8") and reconnect it. You can also order part # RS-DE 245954 the whole cord assembly including the circuit board for about $25.
Will not turn on
There is some misconduct wire, loose or disconnected. Have it serviced, if possible replace the cable :)
1helpful
My dog chewed the cord to my Rowenta Iron
Yes, but not warranty covered.
Check your local yellow pages (yes, printed book) for an apliance repair shop (look for discount coupon in back while you are at it).
Does not have to be an "authorized" Rowenta shop ($20). Get an 8 foot cord if you think you need a longer cord.
The dog can be fixed, too: (I couldn't resist typing that) Wipe some "training spray (pet shop or WalMart $5)" (harmless to dog & environment) onto the new cord (NOT ON THE DOG) to train the dog to leave it alone.
2helpful
Rowenta model dm 860 loose power cord
Most high end appliances (like Rowenta Irons) are made so repairs like that can be done. I haven't played with that model, but I did replace a cord on my Norelco. The torx screwdrivers you are looking for can be purchased, and are often found at either specialty electronic stores (not the average Radio Shack), automotive stores and quite readily online. They are also known as Torx Security bits or Torx Safety bits. Most appliances are made with those screws to prevent the average person from having a go at trying to fix it, but, if you feel comfortable enough with the electronics (even just to look for a loose connection), the bits are available and usually at a fairly decent price.
2helpful
On and off petal switch not working
When I took mine apart I noticed the switch had melted near the contacts. This makes me not want to fix it, but instead, look for a better model. Hope this helps.
16helpful
2answers
Turns on, flashes yellow but never heats up
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Rowenta problem
mY de 87.1C WAS WORKING AN ABOUT TWENTY MINUTES OF IRONING, THE CORD & PLUG IN BLEW & IT QUIT.
3helpful
Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Top Rowenta Irons Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
