SOURCE: Toaster Side wont 'start'
I would say the door interlock switch (or its mount or wiring) has failed.
This is to prevent it from running when the door is open.
It may be shut, but if the signal from the switch is not present, it will not run.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: I have a 4 slice
The toast carriage is held down by an electro-magnet, not by any type of physical clasp or hook.
So the most frequent problem with elector-magnet is due to the heat some wire or springs become loose so the electro-magnet is not working properly so it does not stay down.
Another reason that electro-magnet not work properly is due to bread remaining does not leave the lector-magnet contacts to contact. You should clean between where the metal of the Electrical contact meet each other.
