I have a sunquest pro16s and I need to know is it 110 or 220 the plug looks similar to a dryer plug put I know you need certain outlets for these
Topaz 100mg Buy Topaz 100mg Online, price, Topiramate 100 mg,
SOURCE: 220 volt dryer outlet is
If your home has fuses, one of the 30 amp fuses may be blown. If breakers, not as likely you have a bad breaker, but possible. Check voltage at main electrical distribution pannel. Look for loose connections.
SOURCE: transformer 110-220
Less expensive to replace the heating element. But if you already have a 1000 watt transformer then just go that route
SOURCE: is my dryer 220 or 110 volts
If your dryer has a standard cord (looks like a extention cord) than you can not hook it into 220, it is a gas dryer if you have that plug. If you have a electric dryer it will have a much larger plug and vcan only be plugged into 220
SOURCE: A diagram of how to wire a 220 volt outlet from
You can't really do that. The two 110 outlets probably come for the same 'leg' of the 240. If you check them with a meter, there will be '0' volts between the two hot wires. So, they have the same 'potential'. You need a regular 240 volt circuit from a double pole breaker that is rated for the wire size that it's feeding. 20 amp-#12 ; 30 amp- #10 etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: I Accisentally plugged My 110 Volt xbox 360 into a 220 volt outle
The reason for this is the power overwhelmed the circuit boards and burnt them out you may need to talk to someone up the Game shops or go to support.microsoft.com and see what other people think. even if microsoft tell you to DONT send it in for repair as it gets rattled in the post and rattling the console causes the Open Tray Error an extremley annoying error. hope this helps
