Question about Panasonic Audio Players & Recorders
I have a Panasonic SA-HT75 Unit but with no speakers. Is there anywhere I can find these speakers to purchase?
Posted by Rob Epler on
Grubhead
  • Panasonic Master
  • 5,700 Answers
The Panasonic website would be the place to look and ask them if you can't see them. If they are no longer made they should suggest a suitable replacement.
Posted on Jun 03, 2018
5 Related Answers
Anonymous
  • 682 Answers
SOURCE: Fault code
speaker cord connector problem:-
remove all speaker connectors and insert it one by one each time until you find the bad one and change its connector with a new one.
(you must play something and listen).if all above does not work you will have problem in power supply and need to fix.
Posted on Apr 04, 2008
Benimur
Louie Role
  • 6966 Answers
SOURCE: panasonic home cinema model sa-ht75
F61 error codes could either be IC501 or the regulator (IC502) in the power supply section.
For reference, pls view these two (2) posts here and here of similar concern on other models.
Other possibilities are:
1. fan not turning;
2. cold solder;
3. looses connections;
4. one of the other components/systems hooked up to the power supply is causing a fault (tuner, disc player).
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 26, 2008
Anonymous
  • 51 Answers
SOURCE: My receiver for the Panasonic-SA-HT800V is toast
ebay? the speakers can only be used with this model..unless you strip the speaker wire...
Posted on Jul 25, 2008
Anonymous
  • 29 Answers
SOURCE: I have no manual - can't get the sound to work
http://www.nodevice.com/user_manual/panasonic/dvd_cd/sa-ht75.html
http://service.us.panasonic.com/OPERMANPDF/SCHT95.PDF
Posted on Nov 09, 2009
Testimonial: "Thank you very much for your help. I now have a manual thanks to you. Cheers"
Anonymous
  • 3 Answers
SOURCE: I have the SA. HT75 Panasonic Home theater DVD system
There is a short in the power section. Unit will also shut down.
Posted on Nov 19, 2009
Where can I purchase a cooling fan for my Panasonic DVD Home Theatre Sound System?
How to Fix Panasonic SA-HT75 Fan - Simple Always ON ...
? 2:56
https://www.youtube.com/watch?v=ypL0o5zF_vU
Aug 13, 2012 - Uploaded by Michael "Jack H." Miller
The Panasonic SA-HT75 (and subsequently lots of otherPanasonic ... them from shining: The fan is set to come on and cool your system when the unit ... this out my son he's 8 and he mode yards all summer for a surround sound .... unit but was defective I need the little engine that the dvd is spinning up .
Nov 29, 2015 | Panasonic Audio Players & Recorders
MY PANASONIC SA-HT75 KEEPS ON CLICKING OFF WHEN I SWITH IT ON.WON'T START UP
There Panasonic SA-ht75 dvd Decreasing the opening treading on what's happening back immediately shuts down
Sep 05, 2011 | Panasonic SC-HT75 System
My Panasonic SA-HT75 clicks off seconds after I turn it on. Even got a F61 code.
Open the unit and clean/replace the fan.
If it doesn't turn when you power it on after cleaning it, put some oil on its bearing sleeve.
Never power on this device while speakers are not connected!
Hope this solves your problem!
Feb 23, 2011 | Panasonic SC-HT75 System
Unit displays f61 and nothing works What component is related to this
"Check and correct the speaker cord connections. Page 7
If this does not fix the problem, there is a power supply problem. Call 1-800-211-7262 for support."
http://www.retrevo.com/support/Panasonic-SC-HT75-Home-Theater-Systems-manual/id/356ci969/t/2/
It's implying you have a shorted speaker wire.
Jan 22, 2011 | Panasonic SC-HT75 System
My Panasonic SA-HT75 won't read any DVD/CD discs
The laser has failed. They all go this way. Throw it away and don't buy Panasonic next time.
Jun 09, 2010 | Panasonic SC-HT75 System
Nov 09, 2009 | Panasonic Audio Players & Recorders
Apr 06, 2009 | Panasonic SC-HT75 System
Replacing a Surround Sound System Receiver
the difference is the "same speaker connections"
the front and rear will connect the same but the subwoofer is amplified by the HT75 , and the HE75 does not have an internal amp for the subwoofer speaker , only a "pre output"(has to be amplified)
Mar 24, 2009 | Panasonic SA-HE75 Receiver
Fault code
Mar 24, 2008 | Panasonic SC-HT67 System
41 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
