Question about Locks & Locksmithing
Basic instructions for setting and use How to open after locked
Posted by Carol Burrus on
  • Brett Duxbury
    Brett Duxbury May 30, 2018
    Hi Carol Burrus, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    what is the make and model of the mystery lock ?
Hi, can't connect to internet & open MMS'se or send out. Thanks Amanda my e-mail is [email protected]
Contact network provider they should text you the settings if not Go to
www.filesaveas.com/connect.html for basic instructions and settings for major uk networks
Mar 10, 2011 | Cell Phones
Which one is valet button on the viper 474
No key in ignition, door wide open, press lock-unlock-lock within one second. That will valet the alarm and the led will light up steady. Follow same instructions to remove alarm from valet mode.
Oct 04, 2010 | Viper Security and Remote Start System...
Please tell me how to set teh lock code for my samsonite silhouette 11 HS....no instructions were included! help!!
Sure... here're the instructions - open the suitcase, then open the zipper in the modesty pouch (it is mounted on the backside of the suitcase, along its entire length), and then from in there, take out the plastic packet. In the plastic packet are labels, warranty information, AND voila - the instructions to set the combination lock... :-)
I would tell you here too:
1. Open the suitcase
2. Look at the inside back of the lock - you would see a red color tab, and two markings - A
Aug 30, 2010 | Samsonite Silhouette 11 SoftSide 22"...
Help with child lock instructions
to my knowledge there is not a child lock on this model its at the basic end of the range only upper range models have this feature.sorry.
Oct 14, 2009 | Bosch Classixx WFL 2066 Front Load Washer
How do I program a Viper 473 V Replacement Remote, to my 2004 Hyundai Santa Fe?
Set lock/unlock button
· open drivers door
· turn key to ON position
· press valet switch 1 time
· press valet switch again and hold
· when alarm chirps press lock/unlock on remote
· release valet switch
· turn key off
Oct 05, 2009 | Viper Security and Remote Start System...
Set luggage lock
the lock is currently set to 000. To set your own combination and with the lock in the 000 position, open the case and on the inside of the lock mechanism you will see a red tab. slide this tab to the left and then move the digits on the front to your desired code. ie 123. then move the red tab back to lock in this new setting as your own personal combination. close the case and then move the digits away from our setting of 123 and this locks the case. only if the digitrs are 123 in this example will the lock now open.
Dec 24, 2008 | Locks & Locksmithing
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Replacing LCD screen
just follow the basic steps in opening nokia phone... look for any screws and unscrew it, if thiers no more screw but still you can open it. probably it got locks, so look for it and snap to open it then you open your phone.... in changing your lcd, thiers a flex connector that connects your lcd to its board. to open it use a tweezer to open it and do it slowly to avoid damaging the flex...
good luck...
Oct 10, 2007 | Nokia 7373 Cellular Phone
Locks & Locksmithing Logo
253 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
