File System Error! System error: 3
I have a Phillips GoGear VIBE 4GB. Charged and tried to connect to PC to copy music off of MP3 player. It says fully charged and has MSC beside the pic of the player. The dots under it blink in sync for one time each then off. It responds to none of the buttons. When I unplug it, it opens to the Phillips logo then says File system error! System error: 3 How do I fix this?
Posted by Linda Allen on
Steve Pack
  • Audio Player... Master
  • 4,331 Answers
Try formatting. windows file explorer select device right click select format
Posted on May 30, 2018
2 Related Answers
Anonymous
  • 4 Answers
SOURCE: File System Error
Try formatting it using FAT32 or NTFS file system. I formatted my SA2840 and changed the file system from FAT32 to NTFS (what was I thinking!) and the ending of the story was pretty much the same.
Posted on Dec 12, 2008
shadow83
shadow83
  • 496 Answers
SOURCE: System File Error on Phillips GoGear Vibe
you should be able to put it into recovery mode by holding the volume up button while hooking it up to the computer after that you should be able to do a recovery on it using the software provided with the player
Posted on Dec 07, 2009
How do you down load music onto it?
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Dec 30, 2012 | Philips Gogear Vibe 4gb Mp3 Video Player...
My phillips gogear vibe says that there is no music anymore
Try resetting the MP3 player: locate the little reset hole (it is quite small) and give it a poke with something blunt like a unraveled paper clip.
Oct 21, 2012 | Philips 4gb gogear vibe mp3 playr
Can i use itunes to download music to my philips gogear vibe 4gb device?
itunes uses an M4A file format. You will have to download a file converter, then convert it to mp3. try www.cnet.com and search for audio converter. Lots of free software to choose from.
Jan 11, 2012 | Philips GoGear ViBE Digital Media Player
How do I download songs onto my phillips gogear cam
  • Charge your Philips GoGear ViBE for at least three hours before turning it on.
  • 2 Insert the small end of your mini USB cable into your GoGear ViBE. Insert the other end of this cable into one of your computer's USB ports. Turn your GoGear ViBE on by pressing and holding the "Power" button for two seconds.
  • 3 Insert the Philips GoGear ViBE software disc into your computer's CD-ROM drive. Follow the onscreen prompts to install it.
  • 4 Open "Computer" from the "Start" menu and locate the GoViBE icon to make sure it has been successfully connected to your computer.
  • 5 Navigate to your music files. If you're unsure about their location, start by looking in the "Music" folder under the "Start" menu.
  • 6 Drag and drop your music files from their folder onto the GoViBE icon in your "Computer" window.
  • 7 Right-click the USB icon with the green arrow, located in your taskbar, to disconnect your device. Click "Safely Remove hardware," then wait until your computer confirms that it's safe to remove the device. Disconnect the USB cable from both your computer and your GoGear ViBE.
  • 8 Select the musical note icon from the main menu of your GoGear ViBE to open your music files. Navigate to the sub-folders section, and select a song from either the artist, album, track list or genre. Press the "Play/Pause" button to begin playing a song
Oct 07, 2011 | Philips GOGEAR SA6045 MP3 Player
How do you fix mtp error? It pops up every time i plug in my phillips gogear mp3 player.
I don't now you have SA1.. or SA2.. type of Vibe player but if you have SA1.. you should try this:
From the main menu of the device enter in to settings and select Connect PC preference.Change this from MTP to MSC mode and try the connection with the PC again.
I hope this helps you.
Thanks.
gylacz
Sep 23, 2011 | Philips GoGear ViBE Digital Media Player
Hi i have a gogear vibe 4gb and when i down load music it says its in the wrong for mat. i have tryed to it in mp4 for mat put it dose not work when try to play the music. can you help
This player only plays mp3 music files not mp4 files.
You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player.
For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player.
Jul 09, 2011 | Philips GoGear ViBE Digital Media Player
File system error
Try to reformat it. It might be a virus or a bug.
Apr 26, 2010 | Philips GoGear HDD6330 MP3 Player
Philips GoGear HDD6330 MP3 Player will not sync music files onto it? How do I fix that and has deleted all previous ones! Please help>
This could be the player's connection mode in combination with your synchronization software. If you are using Windows Media Player or Philips Songbird to sync, the player will need to be set for MTP connection mode. Most other software that works with regular flash drives will need the player set for MSC connection mode. Whatever you are using, simply try the other mode.
To change the connection mode, select "PC connection preference" in the Settings menu of the player.
If you found this information helpful, please indicate as such.
Apr 12, 2010 | Philips GoGear HDD6330 MP3 Player
Dec 07, 2009 | Philips Audio Players & Recorders
What video format does gogear vibe use?
my mp3/4 does not play video when you click on vidio it says video format not supported
Jun 29, 2009 | Philips GOGEAR SA6045 MP3 Player
115 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
