How can I fix this?
SOURCE: I have a white bar on the right side of the screen.
This is caused by either a bad address board (low $) or a bad plasma panel (high $). The only way to know is to replace the corresponding address board and see if it repairs the line. Hope this helps.
SOURCE: veritical bar in top right corner
PiP or bad connection. disconnect the set with all cables and reconnect and see what happens
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: How to fix Vertical bar on Samsung Electronics 55 UN55ES7100F?
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
