Question about La Crosse Measuring Tools & Sensors
Received a gift from France: a La Crosse Technology weather sensor TX 29 with atomic clock. It's connected to Frankfurt, Germany therefore out of range and in Celsius. Any chance to modify settings?
Posted by Jerome Sauvage on
Tom Chichester
    Top Expert:
  • La Crosse Master
  • 55,379 Answers
Go to www.lacrossetechnology.com and see what you can find regarding model TX29. I have a LaCrosse 8005 right in front of me and it has a switch for F or C. You also can select your time zone.
Posted on May 29, 2018
5 Related Answers
Anonymous
SOURCE: WS-1510-iT La Crosse Wireless Weather
My 1510-IT came with a faulty battery cover top for the rain guage. There should be a metallic clip mounted to the cover to tie the 2 batteries together electrically. Mine had nothing there. I soldered a wire between the 2 batteries and used some cardboard under the cover to make sure the batteries were pushed down into their holder. Problem solved!
I can't imagine this is systemic but it happened to me.
Posted on Sep 22, 2008
homedesigner
Mark Tidwell
  • 583 Answers
SOURCE: We have an atomic clock with calendar and
Press and hold the SET key for 5 seconds. Press set key repeatedly until TZ is displayed on the bottom. Use the "+" key to set the time zone. -8 is for Pacific Time Zone, it will display -8 PST in the display. Press set to go to the DST setting, and so on until you've cycled through the options.
Posted on Feb 20, 2010
Richard Crate
  • 157 Answers
SOURCE: THE CLOCK IS ON A
Hello. Not certain what you are trying to do with the clock, so I have attached the link to the company's list of manuals. Simply select the make and model you have, and the information should help you. Failing that, the company does have a contact page, and I am certain they will be able to assist. Good luck.
If this has helped, please rate it a four thumbs up. Thank You.
http://lacrossetechnology.com/support/manuals.php
Posted on Mar 29, 2011
Testimonial: "spot on, many thanks"
gopakumarg43
  • 76352 Answers
SOURCE: my La Crosse Radio controled
Hello
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Select a location to place your radio controlled clock where it will be at least six feet away from a TV, computer, air conditioner or other household electrical appliances. The optimal location is near a window. Windows facing Colorado providing the best signal. The WWVB time signal will easily penetrate Masonry and wood framed buildings. WWVB will penetrate almost every residential building and most steel buildings if they have adequate windows. It is not possible, however, for WWVB to penetrate most indoor shopping malls and rooms in the center of large office buildings that do not have windows. In buildings that WWVB cannot penetrate you may set the time using the manual time set button. When the clock is exposed to the WWVB signal it will automatically set the hands to the exact time.
Ok.
Posted on Jul 31, 2011
jmgldsmth
Jim Goldsmith
  • 2005 Answers
SOURCE: how do you change setting from celsius to fahrenheit on atomic clock
switch in the back changes the setting
Posted on Dec 03, 2013
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
How do I get a new outside temperature sensor?
You may have to order a replacement sensor directly from La Crosse.
Apr 29, 2015 | La Crosse Technology Lacrosse Technology...
How to set a Model:WT-8005 atomic cllock
download the manual from here: http://www.manualslib.com/manual/533191/La-Crosse-Technology-Wt-8005u.html
Mar 16, 2015 | La Crosse Technology Black Model Wt-8005...
How do I chage time on lacross clock
An atomic clock, by definition, sets the time automatically.
Feb 19, 2015 | Lacrosse La Crosse Technology Atomic Clock...
How do I chage time on a lacross clock
Hi I am giving you a link to the La Crosse website where you just enter your clock model number and you get the manual for it. There also are videos if you need more assistance.http://lacrossetechnology.com/support/manuals.php
My remote sensor Tx14TH-LCD-B started flashing several days ago and I have gone thru the factory reset new batteries and decided to buy a new sensor then discovered they have been discontinued along with...
I assume you have tried removing the batteries at both ends, reinstalling batteries at the sensor end then the indoor end, waiting without touching anything until the outdoor temp registers and heaving a sigh of relief as things are back to normal. I also assume since the word atomic is in the header that you have an atomic clock function. If nothing works or doesn't work right you probably need to replace the system.
I have a much simpler LaCrosse system which, at this moment, is showing an outside temp of 56 degrees BUT the clock doesn't work and failed early on. I share your frustration.
Nov 04, 2013 | La Crosse Technology La Crosse S98642...
We now have two wall clocks that have stopped. Replacing batteries has not worked. Are they repairable? Can we get new or reconditioned movements?
Hello
Check its battery contacts for any rust or dust. Anyway clean it well and put the pattery, and check whether it is working or not.
Battery - The La Crosse Technology clock must have a fresh battery to receive and process the time signal.
Location - Try a different location, ideally near a window. It should be at least six feet from computers, TVs, air conditioners, other Radio-
Controlled clocks and other electrical appliances that cause interference.
Weather - Electrical storms between you and Colorado during the night will interfere with the WWVB signal.
Although we cannot control the weather we can help you predict it (see www.lacrossetechnology.com).
Daylight Savings Time
The National Institute of Standards and Technology and WWVB encode a special DST "bit" in the WWVB transmission for DST. Your La
Crosse Technology clock will read this information and automatically advance the hands one hour in the spring and eleven hours in the fall.
Arizona and Indiana
If you live in an area that does not recognize DST you must press the (unmarked) DST button for one second to deactivate your clock's DST
program. To reactivate the DST program simply press the DST button again for one second.
If you cant rectify the probelem, contact
La Crosse Technology, Ltd
2809 Losey Blvd. S.
La Crosse, WI 54601
Phone: 608.782.1610
Fax: 608.796.1020
or enter their website at
The device is a repairable one. OK.
Mar 14, 2011 | La Crosse Radio Controlled Atomic Clock
Measuring Tools & Sensors Logo
184 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
