Question about STA-J5C09 500 Amp Jump Starter w/ 120V AC Charger, 120 PSI Compressor, 270 Degree Pivoting LED Emergency Light, 1000 Peak Battery Amps & Heavy Duty Metal Clamps
Can I use the stanley 500 while plugged in the ac outlet?
Stanley 500 won't hold a charge. Can I use it by keeping it plugged in? Trying to charge golf cart batteries
Posted by Hugh McCloskey on
5 Related Answers
Anonymous
  • 161 Answers
SOURCE: trickle charger for storing electric cushman golf cart
contact manufacturer, and seek there advice
Posted on Nov 27, 2008
Anonymous
SOURCE: i am looking for a manual for the Stanley
I downloaded a manual for my Bostitch (stanley) framing nailer yesterday from their webpage. You should be able to find one somewhere on stanleys home page.
Posted on Apr 24, 2009
Anonymous
  • 76 Answers
SOURCE: We are searching for a schematic for a Legend electric golf cart
THE BATTERIES ARE RUN IN SERIES THAT MEANS THAT THE WIRES GO POS. TO NEG. NEG. TO POS. STARTING IN THE BACK AND THEY RUN LIKE THIS TILL YOU GET TO THE OUTPUT FROM BATTERIES TO MOTORS THE CURRENT GOES IN ONE SIDE OF BATTERY AND OUT THE OTHER BY CONECTING ALL POSITIVES YOU MAY HAVE JUST KILLED THE BATTERIES
Posted on Jun 25, 2009
Anonymous
  • 82 Answers
SOURCE: I have 2004 EZgo electric golf cart. When I plug
Check for a tripped circuit breaker. usally at inline with the positive cale of the battery
Posted on Mar 25, 2010
Keith Chick
SOURCE: Given a hand me down Dexton Lil Driver Battery
To charge... you need to remove the seat. Only 2 screws holding it in place. Underneath you will see the battery...you will notice wires from the battery connect to wires from the motor on the wheels...pull apart those 2 connectors and attach the charger...then plug it in to a wall socket and leave connected for a long period of time. I don't remember how long it takes for a full charge...but I'm thinking at least 12 hours. If the battery doesn't hold a charge you can typically get it at walmart or online. Best of luck.
Posted on Nov 30, 2011
My Stanley 500 1000 amp charger/compressor won't charge??
Depends how long the unit has been just 'sitting' without being used! My neighbour had a similar problem after leaving his for over a year unused. The battery that's in it simply died. In order to maintain these units in good working order they need to be used regularly - that is charged and discharged. The unit may need a new battery I'm afraid!
Jun 22, 2014 | STA-J5C09 500 Amp Jump Starter w/ 120V AC...
How do I charge the Fatmax 450 Amp by Stanley
It should come with a DC or AC charging plug. All you have to do is plug it into either the 12v socket on your car, or your AC wall outlet, depending on which plug(s) you have.
Feb 11, 2014 | Vehicle Parts & Accessories
How to charge jump starter
If the battery is real low, It takes about 8 hours to recharge it,
Dec 05, 2012 | Stanley Black & Decker Stanley J5c09 500...
How do you recharge jump start system
put a battery charger for a car on the + and - leads and this will recharge it if you do not have the correct power pack recharge transformer
Jan 09, 2012 | Stanley Black & Decker Stanley J5c09 500...
How long do i have to charge the stanley j309 300 amp battery booster
Before the first use, the unit must be charged for 24 hours with a connection to an AC outlet (120V). Make sure that all of the switches are off. After that, stop charging when two red and one green LED Battery Status Indicators light.
If you are recharging the unit from a 12V battery, do not charge for more than 6 hours. (Check for a full charge by disconnecting the DC charging adapter and then press the Battery Power Level button.)
The manual for the Stanley J309 battery jump starter is available on the product page here: http://www.baccusglobal.com/stanley/j309.php . The direct link to the manual is http://www.baccusglobal.com/stanley/manuals/JUMPERS/J309%20MANUAL.pdf .
I hope this helps.
Dec 29, 2011 | Garden
Can I charge a Polaris battery at 2 amps to keep it charged?
use a small solar panel ,cheap and it will keep the battery up
Nov 09, 2011 | Stanley Black & Decker Stanley Bc1509 15...
Just want to know what the code FLO stands for kid lost the manual
The digital display shows "FLO" to indicate that the unit is in float charge mode. The battery "fully charged" icon will display on the LCD screen and the arrows pointing to the "+" and "-" will flash. In this mode, the unit monitors the battery voltage and charges as necessary to assure the battery maintains full capacity. The unit remains in float charge mode as long as the charger is connected to the battery and plugged into a functioning AC outlet. I hope this has answered your question.
Apr 01, 2011 | Stanley Black & Decker Stanley Bc1509 15...
I've misplaced my users manual for my Stanley J5C09 jump starter
Go to www.baccusglobal.com and link the Stanley link and then the "manuals" link and it should be there
Dec 27, 2010 | Stanley Black & Decker Stanley J5c09 500...
STA-J5C09 500 Amp Jump Starter w/ 120V AC Charger, 120 PSI Compressor, 270 Degree Pivoting LED Emergency Light, 1000 Peak Battery Amps & Heavy Duty Metal Clamps Logo
371 people viewed this question
Top Stanley Vehicle Parts & Accessories Experts
Marvin
Marvin
Lawrence Oravetz
MrFixitSTTL
Are you a Stanley Vehicle Part and Accessory Expert? Answer questions, earn points and help others
