It's 175mmX150mmX40mm ( had 2 brackets with 4 bolt holes in each) With number DGH48574 engraved in side bracket At the top left hand corner it has: ENGINE CONN. 2,top right hand corner: GENERAL CONN.1, bottom left hand corner: ACTUATOR CONN.5, bottom middle SWITCH CONN.4, bottom right hand corner DIAGNOSIS CONN.3. There is also a sticker with program:FEF4094V, Date: 8-8-01, Vehicle Type: EF FALCON 4.0L
(1) No need to know if engine block coolant drain plug was available. Once the water pump was removed, all engine block coolant was drained. (2) After removing the three engine mounting bracket bolts, I also removed the mount bracket from the the body and made enough room to replace the timing belt easier.
SOURCE: toyota mr2 roadster 2001 engine light on code po141 oxygen sens
bank 1 will be whichever side cylinder 1 of your engine is and bank 2 will be the opposite side. It's named bank 1 and bank 2 so that no matter how the engine is laid out, bank 1 is always on the same side as cylinder 1. I cannot say whether the right hand or the left hand one will be bank 1 as I do not know where your cylinder 1 is. The garage should know
SOURCE: my car is blowing smoke and shuddering ef falcon
What color is the smoke ? is it bluish or is it white ?
The blue colored smoke would smell more like burning oil, which would indicate a broken piston ring, ect. the white smoke if it smells of coolant(anti-freeze) would lean toward a head gasket problem.
SOURCE: 2001 galant 3.0L cant figure firing order out. has
For the 3.0L
Firing Order:
1-2-3-4-5-6
Cylinders:
(back of engine)
1-----3------5
2-----4------6
(back of engine)
Distributor:
(back)
4......5.......6
v......v........v
o......o.......o
o......o.......o
3......2.......1
Let me know if this helped or if you have additional information or questions. Feel Free to contact me at FixYa.com!
