Question about Home Security
SOURCE: Lost combination Safe Guard Digital Safe
I used to work for a safe company.
The solution to your problem is not nice.
You need to find someone with a 9 inch grinder and a metal cutting blade.
Don't bother to try to cut the door off it is the strongest part.
If possible cut the back off. If not possible to get to the back start with the hinges if you know where they are, some hinges are concealed and are not where they appear to be.
This solution is messy dirty noisy and dangerous, that's what safes do to deter criminals.
If safe companies kept generic codes to open any kind of safe they wouldn't be,,,,,,,,,,,,,safe.
Posted on Feb 13, 2009
SOURCE: know combination, but cannot open sentry safe 1250
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
Posted on Mar 18, 2009
SOURCE: lost combination to safe
http://www.sentrysafe.com
the instructions are located link above.
mj
Posted on Sep 07, 2009
SOURCE: i have an old Cary
Try spinning the dial ccw 3 times, clockwise to the first number, Turn ccw once past the 2nd number then ccw to the 2nd number, then clockwise to the 3rd number, hope this helps!
Posted on Jun 28, 2010
SOURCE: how do you open a sentry 1250 combination safe? I have the number
Locksmiths agree If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking the Fireproof Sentry Safe open.
Posted on Aug 09, 2010
Jan 28, 2016 | Home Security
Dec 28, 2015 | Home Security
Sep 06, 2014 | Home Security
Aug 18, 2014 | Home Security
Jan 31, 2013 | Sentry Fireproof Safe
Sep 17, 2010 | Office Equipment & Supplies
Jun 28, 2010 | Office Equipment & Supplies
Aug 31, 2009 | Computers & Internet
567 people viewed this question
