Question about Craftsman Tools & Hardware - Others
I need to know how to put that plastic wedge back into my Craftsman stapler model #908514 THE CORRECT WAY?
Posted by Kenneth Leonard on
5 Related Answers
Anonymous
  • 44 Answers
SOURCE: stapler!!!!
The most expensive stapler ACE sells is $35-ish. If something is broken or if you can't get it back together, you may need to replace it.
Posted on May 24, 2009
Anonymous
SOURCE: my craftsman easy fire stapler diagram
Mine stopped working last night. I took it apart and was able to reassemble it properly.
When both sides are rejoined the tip of the spring has to be inserted in the hole on the corresponding side (note red arrows on both pics)
This is a great stapler when it's working.
Posted on Dec 20, 2009
Anonymous
  • 185 Answers
SOURCE: I have a manual Craftsman stapler 68447 and an
you can try here:
http://cgi.ebay.com/NEW-ARROW-1-4-MONEL-STAPLE-504M1-/220606637809?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item335d2e26f1#ht_2432wt_911
I checked the crown website and it is a little bit harder to buy from them
if it works for you don't forget to rate me
thx
Posted on May 21, 2010
Richard Crate
  • 157 Answers
SOURCE: the back plastic part of
Hello. The stapler is manufactured by Swingline. Here is the link to their contact page.
http://www.acco.com/contactus.aspx
If this helps, please rank it a four-thumbs up. Thank You.
Posted on Mar 28, 2011
stuart_barte
Breaktech
  • 56 Answers
SOURCE: HOW AND WHERE DOES THE SMALL PLASTIC WEDGE GO BACK INTO THE STAPLE GUN
How to Use Staple Gun Staple Gun Tutorial
Posted on Jul 22, 2015
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
https://www.youtube.com/watch?v=hWmvXhkqnYI
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
https://www.youtube.com/watch?v=j4Q5W0uKS-s
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya
www.fixya.com > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
Dec 10, 2015 | Stanley SHARPSHOOTER HEAVY-DUTY STAPLE GUN
Loading instructions for craftsman stapler #68514
To load the Craftsman 68514 stapler squeeze the release on the sides near the back and pull carriage out. Add staples and then reinsert the carriage making sure it catches.
Jul 12, 2014 | Sears Craftsman LiftMaster Chamberlain...
How do I make the Optima 20 electic stapler model 48208 work after putting in the staples. I put the paper in as usual and it does not work. I have put the staples in correctly as I normally do, but
Unplug it, take it apart and examine the switch actuator and switch to see why they don't trigger the stapler. There's a good chance you'll find the actuator is broken or jammed by a foreign object, or the switch is worn out. Metal-filled epoxy works well for repairing ABS plastic parts.
Another possibility is a broken power cord. You can test the electrical parts for continuity with an ohmmeter (unplugged, of course!).
Nov 10, 2011 | Swingline 48208 Optima ® 20 Electric...
Just bought and tried to load my Swingline Smart Touch low force stapler. Don't know how to get it opened
I have one of these models. Just push the gray lock mechanism at the end of the stapler and the loading magazine will pop out. The chrome plated magazine opens towrds the front....it slides forward and backwards.
Jun 17, 2011 | Office Equipment & Supplies
How do put staples in this stapler?
vaduvur.jpg1. Hold the black handle -- top part -- of the stapler with your right hand thumb and forefinger. 2. Hold the metal casing right beneath the black handle, with your left hand thumb and forefinger. 3. Use your left hand thumb and forefingers and a wedge to separate the top black part and the metal casing beneath it. 4. Bingo!
Note: Switching the two different operations on to the other hand is unlikely to work.
Mar 14, 2011 | Swingline 87845 Optima ® 40 Desk Stapler
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
My craftsman easy fire stapler diagram
Nov 22, 2009 | Tools & Hardware - Others
Can not put together
No official B&D diagram, but userLovenheim from http://www.fixya.com/ posted his/her own picture which I'm posting here: 8d59edb.jpg
Aug 05, 2009 | Black & Decker 5700 Powershot Forward...
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
Tools & Hardware - Others Logo
214 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Mike
Sheldon Dedek
efs_perpends
efs_perpends
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
