Question about Bryant Heating & Cooling
Bryant AC Model: 165ANA018-B - Circuit Board: HK38EA004 has [Y.C.R.LS] my 3 wires are Green, Red, White. How to connect back again?
Thomas Woodburn
  • 2,567 Answers
You need to check at the indoor unit to see how the condenser wire is wired in. Remember. just because a wire is red does not mean it goes to R. Your three connections will go to R, C & Y but no one could tell you what color goes where without looking at your inside unit.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on May 28, 2018
5 Related Answers
Anonymous
  • 473 Answers
SOURCE: Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Posted on Nov 16, 2007
docjohn174
john gagnon
  • 943 Answers
SOURCE: Maytag dryer MDE4000AYW change 3 prong to a 4 prong
HI thanks for your question. the red to red black to black white to white green goes to the fram of the dryer. thanks hope i was helpful. please rate my answer.
Posted on Oct 12, 2008
j_warenzek
  • 49 Answers
SOURCE: Avanti EWC-12 circuit board replacement (correction)
the green an yellow wire is a ground. Look for an area on the board with a ground symbol earth.gif. Can you not match the location from the old board???
Either way the black and red are your positive and negative power, while the third is the ground. The wire probably are located in close proximity to each other.
Let me know if this helps
Jer
Posted on Jan 16, 2010
Anonymous
SOURCE: Wires came loose of control unit from circuit
Rotate the iTrip AutoPilot FM Transmitter controller so that its buttons are facing up and its data cable is on the left side. The data cable wires attach to a row of contact points along the left side of the circuit board as follows (from top to bottom):
1 = Purple
2 = White
3 = Blue
4 = Red
5 = Black
6 = Brown
7 = Green
8 = Yellow
9 = <unused>
Posted on Apr 22, 2010
Anonymous
maybe we can help each other out with the questioni have my white black and red still connected but the purple blue yellow green and brown cables are un soldered if u look at the transmitter with the buttons on the bottom and the screen at the top the wires should be on your right there should be nine spots strating from the bottom to upward skip 1 next one should be white then skip one next should be red then next one is black and then thats all i have hope we can help each other
Posted on Aug 20, 2010
Switching 3 prong cord to a 4 prong cord
if theres a wire from the center terminal on the dryer terminal board going to the dryer case disconnect it,then Red & Black on the cord go to the outer 2 terminals on the dryer terminal board,the White goes to the terminal in the center between where you put the Red & Black wires this is the Neutral wire,then the Green wire connects to any metallic portion on the dryer case as this is the SAFETY Ground wire and also Red & Black can go on either outer terminal on the dryer terminal board as these are not polarity sensitive because its A.C. power so wire it on the dryer terminal board as in (RED-WHITE-BLACK) on the dryer terminal strip and connect the GREEN to any Metallic portion of the dryer case
1helpful
New switch GE model 15265 ... to light up 2 lightbulbs outside. Old switch all cables are black. Those who light up the tester are the hot=Red/black?? Those which do not light up are white?? Green I know...
Manual for GE 15265
http://waterheatertimer.org/pdf/GE-15265-manual.pdf
15A timer works fine on two bulbs, up to 1440 total watts.
If old switch has 2 screws plus green ground screw, then timer is right.
If old switch has 3 screws plus green ground screw, 15265 doesn't replace 3-way switch.
Timer-green wire connects to bare ground wire
Old switch has 2 screws with wires on each.
One wire is Hot-from breaker and this connects to timer-black wire.
One wire Goes-to-lights and this connects to timer-red wire.
If you get these two wires reversed, timer will not work, so reverse them.
It will not blow circuit if the timer-red and timer-black wires are reversed.
Timer-White wire is the confusing wire for everybody:
Timer-white wire runs clock motor located inside timer.
In back of electric box are neutral white wires that are twisted together and covered with wire nut.
Connect timer-white to these neutral wires.
If box does not have neutral white wires, connect timer-white to bare ground wire.
I have a bryant model 702b packaged unit with 5 wire thermostat wiring coming out of the unit. R Y B G and W. The thermostate in the house is 5 wire and goes to the old central unit and them has a 4 ire...
R-Red is power
Y-Yellow is cool
B-Blue is cool as well
G-Green is fan leg
W-White is usually heat Leg
If you have no indoor unit and this is a ac/gas or
electric outdoor unit try this.
R to R/Red to Red
G-G/Green to Green
Y-Y/Yellow to Yellow
W-W/White to White
-Dont Hook up Blue.
Turn power back on turn the fan to on,fan should run
Turn to Heating, heating should come on
Turn on Cooling,if cooling does not come on switch yellow with blue.
1helpful
561CJ060-a bryant air conditioner two control wires disconnected
Sorry if I am answering this 2x. If it is just A/C then the red and white probably go to the coil for the contactor that cuts on the fan and compressor. If it is a heat pump then they probably go to a circuit board. Red to R terminal and White to W1 terminal. Let me know what you find.
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
18helpful
2answers
Wires came loose of control unit from circuit board do you know what order they should be soldered back Green, white and yellow wires are still connected but I don't know where/which terminal to...
1 = Purple
2 = White
3 = Blue
4 = Red
5 = Black
6 = Brown
7 = Green
8 = Yellow
9 = <unused>
36helpful
10answers
Creative Speaker Of Model SBS-370 The Volume Control is not working, How to directly Connect those two Wires connected to Volume control,bypassing the Volume Control Switch
1. connect:Both Ground (copper wires) with Green wire
2. Connect Red with Blue and
3. Connect White with Yellow
This will give Stereo Output.
Ac unit central
Sorry, we don't have water cois in our area.
Heating & Cooling Logo
Top Bryant Heating & Cooling Experts
Dan Webster
Dan Webster
john h
Tom Chichester
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
