Everything is properly programmed, but I cannot bring up the repeater. I have back monitored it and know it does transmit, the offset is correct, so I have it narrowed down to the repeaters not 'hearing' the PL tone. (Tried many local repeaters to verify).
SOURCE: monitor shuts down after 20 minutes
Sounds like the monitor is overheating. The internal power supply maybe going bad. Ray
SOURCE: Problem Recieving
First try programming the Receiver for Carrier only Squelch,,ie no PL /TPL, then check if it will receive the repeater OK.
If the audio still cuts in and out then (assuming no fault exist) either you mis-programmed the Frequency slightly, or the TPL choice was incorrect.
There is also a possibility of a Bandwidth mis-programming.
Repeaters may have 12.5 KHz or 25KHz channel bandwidth. Basically if you set your radio to 12.5 KHZ and it receives a transmission from a 25Khz Repeater because of the higher repeater TX Deviation the audio on your radios RX will cut in and out and may sound distorted and very loud as well. Your radios TX would sound OK though, but would have lower audio level when heard on the repeater RX. Does your TX work OK through the TPL repeater?
SOURCE: No sound coming through speakers from microphone
ok i have windows vista so u have to right click on sound icon speaker then click playback n select conexant high definition smartaudio 221 n right click it as default n u gotta re load up acid then right click n insert audio
SOURCE: Acer x193w LCD Monitor repeatedly auto configures.
Here is a link to get the manual:
http://www.acerpanam.com/synapse/data/7117/documents/X193W%20(Qisda)%20user's%20manual.pdf
Starting on page 15 are the directions for the monitor controls. Page 17 indicates a "RESET" feture to Clear the Old-Statuses of "Auto-Configuration". There are quite a number of setting for this monitor.
SOURCE: I HAVE A NEOVO E-19A MONITOR. ON BOOT UP SCREEN
http://www.devicemanuals.com/guide/LCD/AG%20Neovo/AG-Neovo-S-19A-LCD-Display-English-Owner's-Manual-T1RjMU9Uaz.html
dlc.sun.com/pdf/820-0119-10/820-0119-10.pdf
http://www.scribd.com/doc/3082274/AOC-LCD-Monitor-786LS-Service-Manual
Use these training manuals, to troubleshoot and sort your issue out.
Above is a user manual, and a service manual, in the service manual, are the troubleshooting steps to perform to isolate the problem, and hopefully repair.
