Question about Dual Car Audio & Video
How to bypass video lockout feature on Dual XDCP97BT head unit
Posted by Chris Park on
5 Related Answers
Anonymous
SOURCE: video while driving; Lanzar sdmu head unit
Just ground the "brake" wire from the unit.
Posted on Dec 24, 2007
Anonymous
SOURCE: dual xdvd-700 video bypass code
Make a connection to the ground side (-) or negative side of your starting battery.
Posted on Apr 29, 2008
Anonymous
SOURCE: parking brake bypass code on a Dual XDVD9101 head unit
I had the same problem. This is what you do. You need a toggle switch a simple on and off switch. Connect your ebrake wire to the toggle switch and then a wire that is grounded to the toggle switch. Turn on your dvd player and when the warning message appears turn your toggle switch on and off and on and then you will be able to watch your movie.
Posted on Mar 27, 2009
Anonymous
SOURCE: video bypass for dual xdvd700 without remote
i used a switch, to the ground, and i'm still having problems, so yeah lol
Posted on Jun 17, 2009
prodcali
Robert Salgado
  • 200 Answers
SOURCE: bypass my alpine INA-W900BT
I Think I Know What You Are Talking About, The Red Wire That Goes to your break or what ever it is that locking you from video .. connect it power to that it is always running.
Posted on Jan 17, 2012
Jensen vm9314, how do you bypass the parking break safety feature to watch videos any time?
Try connecting the PINK wire of your head unit to a ground/chassis of your car. That should solve your problem. happy viewing but drive safely. dreamsystems
Feb 15, 2011 | Audiovox Jensen Vm9314 Dvd Video Bypass...
Clarion nx700 parking break bypass
Wrong. To bypass the lockout feature so you can see the DVD play anytime - you need to toggle the green wire away from ground (from Low to High - i.e. momentary switch) so the radio sees the rising edge of the 12Vdc signal. The green wire is normally high and is tied low. When you put the parking break on - it opens the loop.
A switch will trigger the Opto Isolator inside the head and bypass the lock out feature. This works fine - or you can spend the $25 on the bypass module - that does the same thing - but works as an electronic toggle ~ based off the remote wire and an internal relay in the module. The module will toggle the green wire every time the radio powers up.
Jul 01, 2010 | Clarion NX700 Car Video Player
I have a xdvd700 dual and want to bypass the brake thing but no remote is there anyother way?
Usually there is a handbrake connection that needs to be grounded to the chassis in order to bypass the screen lock. I normally wire it though a switch to ground and back to the handbrake, so if the car is inspected it works like it should.
Some units feature a footbrake wire that needs to be pulsed as well. This is harder to override. I use a bypass device from Peripheral called the PAC-TR7.
Dec 06, 2009 | Dual Electronics XDVD700 Car DVD Player
Video bypass for dual xdvd700 without remote
Jun 17, 2009 | Dual XDVD8181 Car Video Player
Need play player driver
This link may be of help to you:
Dual xdvd 710 bypass hack bypass lockout code 100% work or money ...Dual XDVD 710 in dash unit. and fed up not benefit from full features, ... should not installed in such away that driver may distract or watch , ...
store.payloadz.com/str-asp-i.189693-n.Dual_xdvd_710_bypass_hack_bypass_lockout_code_100_work_or_money_back_eBo... - 202k - Cached - Similar pages -
May 05, 2009 | Dual XDVD8181 Car Video Player
My Maytag refrig. water dispenser & ice maker has ceased to work
there is a "control lockout" feature on the newer dispensors, ( not controlled by you(there is a control lockout feature)but I dont thinkn this is your issue.. the control lockout has somehow sensed a flood of water and for safety reasons has shut off the dispensor, the only way to reset this is to reset the control module, . You can either call for an autorized servicer to come reset, or if you feel up to it there sould be a trouble shooting/tech sheet taped to the underneath of unit, in the front right corner(behind hte kickplate)..
Jan 10, 2009 | Maytag Refrigerators
Dual XDVD700
How to get code for xdvd 700
Apr 28, 2008 | Jensen VM9510 Car DVD Player
How do i by pass the parking brake no video
1. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
2. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
From here:
http://forum.ecoustics.com/bbs/messages/4/302701.html
Oct 09, 2007 | Dual XDVD8181 Car Video Player
Avic n2
You have to bypass the Parking Safety feature. Here is the info I have found. I have not verified it myself for accuracy, so use at your own risk. AVIC-N2 lockout bypass: Underneath the MAIN unit (not the hideaway) is a small silver sticker, peel this back. There are two contacts with the label "R197". Drop a bit of solder between these to connect them. Also, you must ground the Parking Brake wire.
Sep 26, 2007 | Pioneer AVIC-N2 Car DVD Player
Car Audio & Video Logo
941 people viewed this question
Top Dual Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
