Hlo, pls how can i get my site to load faster, the site is so slow that it takes 8 secs to load.pls a brother needs help.also how can i increase the site search rank its a music site
The site loads very slow and this is affecting its google ranking.pls help
A slow computer could be
caused by a number of things -
1.Insufficient
RAM (memory) - if your computer has less than 512Mb of RAM then increase it to
at least 1Gb of RAM.
2.Registry
problems - clean and repair the registry, it will contain unused registry keys.
Use programs such as Registry Mechanic, Microsoft RegClean etc.
3.Uninstall/remove
unused programs, this will also free up hard disk space.
4.Not
enough hard disk space - swap file space may need to be increased if Windows
hasn't been configured to manage it.
5.Install
latest Windows updates.
6.Update
virus definition files and scan computer for viruses, Trojans, malware etc.
7.Clear
the Internet cache for faster browsing.
8.Hard
disk maintenance is required at least once a month to keep it functioning
efficiently.
Run
the following programs - Disk Cleanup -
removes temporary files that are no longer used and to recovers hard disk
space.
Disk
Defragmenter to make fragmented files into contiguous files and therefore
the hard disk access is faster.
A slow computer could be caused by a number of things - 1.Insufficient RAM (memory) - if your computer has less than 512Mb of RAM then increase it to at least 1Gb of RAM. 2.Registry problems - clean and repair the registry, it will contain unused registry keys. Use programs such as Registry Mechanic, Microsoft RegClean etc. 3.Uninstall/remove unused programs, this will also free up hard disk space. 4.Not enough hard disk space - swap file space may need to be increased if Windows hasn't been configured to manage it. 5.Install latest Windows updates. 6.Update virus definition files and scan computer for viruses, Trojans, malware etc. 7.Clear the Internet cache for faster browsing. 8.Hard disk maintenance is required at least once a month to keep it functioning efficiently. Run the following programs - Disk Cleanup - removes temporary files that are no longer used and to recovers hard disk space. Disk Defragmenter to make fragmented files into contiguous files and therefore the hard disk access is faster.
Hi brother
I will suggest you some way to increase your speed of the PC assuming that your system is booting up normally and after loading OS only it is showing slowness
1) Please START then RUN then type msconfig and press ENTER. Click on the Startup tab and uncheck any program that you do not need to start when the system starts. See if that helping you. 2) If that is not working check with Task Manager see how much of the installed memory is being used (PF Usage). You will probably see it higher . In the process tabs with no Applications running your system idle process should me around 98%. If it is not, I would suggest that you run your antivirus and spyware programs (besure they are up to date). 3) Open my Computer>right click on the C: drive>Tools tab. Run both test in this window. (scandisk and disk defragment)
other wise check with service center for any comparability issues
please support me brother
Take care!
There are couple of troubleshootig steps which needs to be performed inorder to help get a web page load faster.
Go to Tools/options/ and delete the history, cached pages, cookies, password etc. Might want to ignore favourites.
Also type temp in run command line and then delete the files from the folder. This helps to increase the processing speed as well as the browsing speed of the accer.
Sorry for the glitch but it would seem the site's server had a problem and we were disconnected.
If OK with you, I would just post the next steps/procedures here. Additionally, I sent an email to the site moderators to look into how we can resume the Live Chat.
Pls comment/post back.
Again my apologies for the inconvenience.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
