Question about Denon Audio Players & Recorders
Denon avr-s710w no video but sound, should I look for HDMI board replacement or individual component?
Posted by Walter Majewski on
5 Related Answers
Anonymous
SOURCE: no HDMI video output from AVR-588 receiver to plasma TV ???
You can also use a digital coax cable (color orange) to go into coax 1 for DVD coax 2 for cable box. Just make sure to set the coax in input settings. The coax cables are a little cheaper than the optical cables and work just as well.
Posted on May 10, 2008
Anonymous
  • 43 Answers
SOURCE: HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Posted on Jan 06, 2009
Gurudristi
Sachin
  • 98 Answers
SOURCE: How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Posted on Feb 27, 2009
petraman7
Scott Frye
  • 1175 Answers
SOURCE: Denon avr-1909 crackling sound while watching Uverse HD.
It may may the the AT+T box is really not compatible with the AVR or the Pioneer.
Check the specs on those input/outputs for the Ubox and the receiver.
See if they agree. If so, try another hookup method like HDMI ( which carries the audio too)
Posted on Apr 11, 2009
Anonymous
SOURCE: No audio running TV through Denon AVR 1910
I had the same problem. You're not doing anything wrong. the thing is you can't (I don't know why but the owner manual says it) have sound going to your tv AND your HT speakers when you're using HDMI. You should try going to input setup, choose hdmi audio out to your TV instead of the speakers, and then run an optical cable from your satellite to your receiver, assigning it to the TV/Cable input.
Posted on Jan 20, 2010
Onkyo DX-C390 with Denon AVR-S710W? This doesn't seem to work when input to the amplifier's media player audio inputs. Do I need a preamp?
Both of the devices have optical connections, by getting a lead between the two you should hear the high quality sound from the unit. Make certain the optical connection is switched on and assigned to the Onkyo.
Only a record player requires a pre-amp. If it the amp doesn't have a dedicated socket for it.
Can I make the Denon AVR-2307Ci receiver have a passthrough for 3D?
I believe it is like my Denon AVR-3808 as it's a HDMI v1.3 compliant. For 3D you need 1.4. So I now use optical cables to the AVR and HDMI to the TV. Then config the DNLA player to split the video to HDMI and the 5.1 sound to optical.
My denon avr 3805 has no hdmi ports. how do i connect my comcast cable box to it.
The only way would be component cables, and digital or analog audio cables. I believe there are HDMI to Component convertors as well.
1helpful
Can't Get 360 to Work
Your receiver is not capable of upconverting analog to HDMI (digital). You will need to add component video cables either from the Denon to the TV or simply straight to the TV from the XBox. Audio should be handled solely by the Denon receiver.
Hi denon to cable box to samsung lcd
Unless you are having res. issues you can use component / optical / coaxial cables to connect all your devices to your denon and from your denon to your tv using component cables also
No video
The Denon does not down scale you can not plug a DVD or other device in to the Denon using HDMI and have it come out Component, if your projector only has Component video inputs you must use Component video connections from the DVD and Cable box to the Denon
4helpful
2answers
Connect and Enjoy
Denon AVR-887 and Wii
I'm dealing with the very same frustration. Best I can tell, the problem with my setup is that this model (avr-887) can't pass component video input out through HDMI. Can anyone confirm that?
Prior to setting up the Wii, I'd only been using a single HDMI output from the denon to my tv/monitor.
The only solution I've found is to add a component video output to the monitor -- which is unfortunate. I'd much rather have only the single HDMI out.
Would love to hear if there is a way to set this up without having to add the additional component output...
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
tina gallow
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
