Question about Kwikset Locks & Locksmithing
How do i remove a code from a kwikset lock model 909?
Posted by Andrea Phillips on
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: how do i change the code in my kwikset 909 keyless
un screw the back cover located on the inside of the door , unscrew the two srewa inside that holds the front key pad , when it is removed you will find is has couled tags inside that are placed on regired key numbers for entry good luck
Posted on Dec 02, 2009
Anonymous
  • 160 Answers
SOURCE: WHERE CAN i FIND A MANUAL FOR MY kWIKSET SIGNATURE
I think this is what your looking for... click link below.
http://www.kwikset.com/smartseries/smartcode.aspx
click on the correct link to your system at the bottom of the page when you get there.
Best,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Posted on Jan 21, 2010
Coaltowner
  • 963 Answers
SOURCE: H do I reset all
This link will take you to the PDF image of the installation and programming instructions:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
(PDF files require that you have Adobe Reader or similar installed on your computer
http://get.adobe.com/reader/ )
It's a good time to replace the batteries while you're reprogramming. Please review each step carefully, because it's easy to goof up this programming process, if you don't follow the procedure properly.
Posted on Jun 27, 2011
Coaltowner
  • 963 Answers
SOURCE: our kwikset 909 will not lock on its own- we have
For reference, here is a link to the installation guide:
Under Step 11, you will see that if you change the switch position of the second switch (of 4) internal to the lock to the ON position, it will enable auto-lock of the door 30 seconds after unlock.
Hope this helps!
Posted on Jul 20, 2011
Coaltowner
  • 963 Answers
SOURCE: [email protected] do i reset a
Here's the installation instruction link for your lock:
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
Posted on Nov 05, 2011
Reset code kwikset
Here is the link to an excellent video of how to install, hand, and program the Smartcode 909. It includes switch-0controlled features of the lock:
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Sep 18, 2012 | Kwikset 909 909-15 Satin Nickel Smart...
I want to remove the old cod
This model lock will hold 2 codes, so apparently all you've dons so far is add a second code. Try reprogramming it again, using your newer code again so it will overwrite the older one. In other words, you will have two codes entered, both will be the same.
If this doesn't work for you, contact Kwikset Customer Service from this link:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Jul 30, 2012 | Kwikset 909 909-15 Satin Nickel Smart...
Need to reset code
Here is an excellent video of how to install, hand, and program the Smartcode 909. It includes switch controlled features of the lock:
Installation instructions:
Jul 17, 2012 | Kwikset 909 909-15 Satin Nickel Smart...
Kwikset keypad deadbolt will not lock or unlock. Batteries OK.
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
Apr 10, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
The dead bolt handle started turning the wrong way so cant use code only key and now if i put a code in nothing happens but when i hit lock i closes the wrong way
Here's the info on your lock:
http://www.kwikset.com/Products/Details/Electronic-Locks/909-15-SMT.aspx
Clicking on the link "Installation Guide" will take you through the programming steps:
I think you'll find your answer there.
Mar 03, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
I have installed my smartcode lock correctly, but it still will not unlock? It locks well but will not unlock???? I have gone back over the steps 4 times and now I;m getting a little frustrated.. I have...
Here's a link to the Kwikset 909-15 information page:
Following the link to the Installation Guide:
On Page 8 starts the Frequently Asked Questions. Please pay close attention to the possibilities listed there--I think you'll find a solution to your problem there.
Customer Support: http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Feb 20, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
How to reset code
Feb 15, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
I replaced the batteries. After inserting them back into the system, the lock does not operate. I have tried pushing program button 3 times and waiting 10 seconds, nothing. I removed the batteries again...
Here is a link to the complete set of installation instructions for the Kwikset 909-15:
If, after following the instructions for replacing the batteries and reprogramming the lock it still doesn't work for you, I suggest contacting Kwikset Customer Support:
Kwikset Corporation
Consumer Service
19701 DaVinci
Lake Forest, CA 92610
Call: 1-800-327-LOCK (5625)
This is a link to the customer support page:
Feb 02, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
We have a kwikset keyless entry lock and need to reset it.
Try searching the type of kwikset lock from this page:
http://www.kwikset.com/Customer-Support/Product-FAQs/Search-Faq.aspx?prod=FAQ+Categories_Keyless+Entry
Jan 22, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
How do i change the code in my kwikset 909 keyless entry
Nov 29, 2009 | Kwikset 909 909-15 Satin Nickel Smart...
Locks & Locksmithing Logo
1,520 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Charles Tidwell
ray gallant
STEVE SPAM REMOVER
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
