Question about Jabra Cell Phones
Can a Jabra Cruiser be paired with my new iPhone 8
Posted by Judi Smith on
5 Related Answers
Anonymous
SOURCE: JABRA BT250V Hearing Problem
Cannot get my Jabra BT 250v to work with my Blackberry Curve 8310. Phone indicates I am paired, but there is no audio through earpiece. You can still hear audio through phone. Help.
Posted on Jul 22, 2008
saish naik
  • 206 Answers
SOURCE: Jabra BT135 won't pair with my Iphone -
take the Bluetooth device and keep its button pressed till the light stables that is u will have to hold the button for more then 10 seconds!!! then once the light is stable keep it like that and take the phone and search for Bluetooth devices it will find it now and then enter the pin given in the manual or mostly it is 0000 and pair the two devices now u are ready to use it!
enjoy!
reply and rate!!
Posted on Jul 15, 2010
Testimonial: "Wow - what a fast answer! Really much appreciated, thank you. I did just as you said and got my bluetooth headset connected straightaway. Once again - thanks for the superfast response"
Anonymous
SOURCE: how do i pair the
Just did it myself. Ensure the iPhone is discoverable and searching.
Switch the Stone off by squeezing down the control surface until it bliddle-omps.
Put it into pair mode by squeezing the thang again until the bluetooth light flashes. Keep squeezing.
Watch the iPhone - it will pair automatically - no password required.
Posted on Oct 11, 2010
supernova278
Udhaya Rajan
  • 1932 Answers
SOURCE: I purchased a new Iphone and my Jabra will not
To remove the list, press and hold the Answer/End button, Volume up button and FM button at the same time. A beep indicates the list was removed from the speakerphone memory. The next time you power on, the speakerphone will go into pairing mode as the first time you powered your new Jabra CRUISER on.
Thank You
Posted on Nov 12, 2010
supernova278
Udhaya Rajan
  • 1932 Answers
SOURCE: Just purchased Jabra Cruiser 2.
Try to reset and pair it.To reset follow below instruction
Thank You
Posted on Nov 15, 2010
How to pair the samsung galaxy s4 to the jabra cruiser
  • Touch Apps
  • 2.Scroll to and touch Settings
  • 3.Ensure Bluetooth is turned on
  • 4.Touch Bluetooth
  • 5.Slide the Power switch to turn the JABRA CRUISER on
  • 6.Press and hold the Multifunction button until you have a rapid flashing blue LED
  • 7.Touch the JABRA CRUISER in the list of devices
  • 8.The JABRA CRUISER is now paired
  • 9.The JABRA CRUISER and Galaxy S4 are now ready to be used
  • 10.Press the FM button in order to start streaming audio via the FM transmitter. The FM LED will turn red
Oct 01, 2014 | Jabra Cruiser InCar Speakerphone Black
How do I "pair" the Jabara Journey with a I Phone 5C?
most pairing when asked by the device requires a 00000 passcode
but you need to set the jabra and the iphone up for pairing
here is a link for jabra the iphone should see it when the jabra is set to set up mode..
http://www.jabra.com/support/Jabra-JOURNEY_100-47300000-15
Oct 11, 2013 | Jabra Cruiser InCar Speakerphone Black
I'm having difficulties pairing my iPhone 5 with my Jabra Cruiser. The unit appears to be in pairing mode when it turns on (flashing), but I never receive verbal confirmation from the unit. I'
the Jabra Cruiser is most likely not compatible with your iphone 5. Apple makes their products to connect only with their products most of the time. ive tried connecting my tracfone\'s bluetooth to my ipod touches bluetooth and cant pair them. Xbox 360 pulls the same issue too. so you probably will have to purchase a different car cruiser
Apr 18, 2013 | Jabra Cruiser InCar Speakerphone Black
How do i make my jabra work with my blackberry
Hi there, You need to pair the two devices. Make sure the cruiser is off, then push and hold the power button the Jabra for 8-10 seconds until it is in pairing mode. You need to continue holding the button after the device has powered on until you get there. Once there, on BlackBerry go to Bluetooth settings and select search for a device. Select the Jabra Cruiser and put in the passkey - 0000. You have now paired the two devices! Alex
Jun 03, 2011 | Jabra Cruiser InCar Speakerphone Black
I'm having trouble pairing it with my iphone4.
when you turn blu tooth on on the iphone under settings. make sure its discoverable and then scan while holding down the jabra cruiser in car speaker phone pairing option
Mar 26, 2011 | Jabra Cruiser InCar Speakerphone Black
My wife lost her iphone and i cant get her new iphone to pair with her old jabra blue tooth
Hello Chris,
Did you try going into "discoverable" mode in the headset?
Please follow these steps and this should help you pair it with the iPhone.
1. Go to Settings > General > Bluetooth 4. Ensure Bluetooth is turned On 5. Ensure the headset is turned Off 6. Press and hold the Answer button until you have a solid blue LED 7. Touch the headset in the list (on iPhone) 8. The passkey is 0000 (4 zeros) 9. Enter the PIN 10. Tap Done
If that's not the problem, then let me know. I'll be glad to help you out.
Please rate this solution if it helps you.
Feb 18, 2011 | Jabra Cruiser InCar Speakerphone Black
Reset iphone need assistance please to start jabra again
but the speaker in pairing mode by pressing and holding the multifunction button until the blue led flashes.
on the iphone, go to settings, 'General' and then 'Bluetooth' and select to 'On'
the iphone will find the speaker and it will appear in the list. when it does, tap it.
tap 'Pair'
you are done.
Dec 17, 2010 | Jabra Cruiser InCar Speakerphone Black
Cannot get my new Iphone 4 to pair with my Jabra cruiser bluetooth. I am in the setting and have the phone looking for the the Jabra but can't find it?
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Nov 22, 2010 | Jabra Cruiser InCar Speakerphone Black
I purchased a new Iphone and my Jabra will not pair. I removed the Jabrsa connection from my old iphone and the Jabra still will not connect. How to reset Jabra and pair new phone?
Thank You
Nov 12, 2010 | Jabra Cruiser InCar Speakerphone Black
Cell Phones Logo
83 people viewed this question
Top Jabra Cell Phones Experts
Anthony Ward
Anthony Ward
Tom Chichester
SANTHOSH
Are you a Jabra Cell Phone Expert? Answer questions, earn points and help others
