Question about Krups Coffee Makers & Espresso Machines
Algu?m possa responder erro c?digo 9 krups xp7220
Posted by vera neves on
Ross Keen
  • Krups Master
  • 1,364 Answers
O sensor de temperatura na parte frontal da carca?a da caldeira (atr?s do painel frontal) n?o est? detectando nenhum calor na caldeira. Freq?entemente ? o borne de terminal desconectado do sensor ou o sensor inteiro n?o est? mais preso na caldeira. A solu??o da Krups ? para substituir a caldeira completa, mas no passado, eu revendi o terminal de volta ou colei (com cola resistente ao calor) o sensor de volta para a caldeira.
Posted on Jun 11, 2018
4 Related Answers
teckman45
Robert Hamilton
  • 52 Answers
SOURCE: Código de erro: -5009 :
If you are installing from a cd, It may need to be cleaned. Follow the directions below, it should resolve the problem.
1. Go to the directory that holds the file for launching the installation (for example, Setup.exe).
2. Right-click on the installation file and select Run As.
3. Uncheck the box that says Protect My Computer And Data From Unauthorized Activity, and click OK.
Another possibility for resolving this error is to run Windows Update on the system before running the installation routine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_33deecd2f8e91168
Posted on Aug 02, 2009
Tom Torre
  • 279 Answers
SOURCE: Krups XP-7220 Error code 01
Go to krupsusa.com and click on "instructions" they should have the manual to download.
Posted on Sep 18, 2009
Anonymous
  • 19 Answers
SOURCE: I have a Krups XP7220.The
When you brew a cup is the coffee cold? Or is just the excess water that come out into the water tray cold?
Posted on Sep 20, 2010
ZJLimited
ZJ Limited
  • 17970 Answers
SOURCE: Minha cam digital Kodak aparece com código de
O problema ? que a lente se tornou presa no cano. Existem algumas solu??es DIY, voc? pode tentar, mas a probabilidade ? que voc? ter? de obt?-lo fixo por um profissional. Use estas por conta e risco, pois pode prejudicar ainda mais a c?mera:
Em primeiro lugar, tente conectar o adaptador de corrente alternada ou cabo USB.
Tente segurar o bot?o do obturador quando ligar a c?mera.
Olhe para a lente, e se alguns dos "c?rculos" a lente est? desalinhada ou n?o conc?ntrica e tente mexer-lo (mantendo lente da c?mera para baixo).
Tente gentilmente empurrando ou puxando a lente quando ela se estende, mas isso ? arriscado, pois pode causar a lente para escapar de seu sistema de orienta??o.
Outra maneira de fazer isso ? colocar a lente da c?mera sobre uma superf?cie dura e, em seguida, poder-se. Tenha certeza de usar um pano macio ou algo similar para n?o arranhar sua lente ou inv?lucro. Vamos empurrar a lente da c?mera para cima e para baixo algumas vezes e ?s vezes a resist?ncia do pequeno fornecida pela c?mera ? suficiente para fazer as coisas andarem novamente.
Tente acertar a c?mera perto da lente no corpo com o tecido mole na palma da sua m?o.
Fora isso, eu tomaria a c?mara a um centro de repara??o de uma avalia??o para ver se ele custaria mais do que a repara??o para substituir a c?mera.
Visite aqui: LENSS ERROR
Boa suerte.
Posted on Dec 31, 2010
KRUPS XP7220. I need help to identify the tube diameter and properties so i can buy a new one. I will need too the reference/size of the metal screw clamps that hold the tube to both ends.
Hi Rui, why not just order the correct parts? The high pressure silicone tubes are all the same diameter but the service data does not say what it is . The part number for the longest tube is OAO1478 and the hose clips are part number OAO1451
Jun 20, 2017 | Krups Coffee Makers & Espresso Machines
Xp7220 has a machine fault of No OC
Faulty communication between the 2 pcbs or distributor is drawing too much current
Dec 16, 2013 | Krups XP7230 Compact Super Automatic...
Error code 3 on krup xp7220
Direct from repair manual for your model, these are the possibilities
- Fault in the actuator high
position switch (mechanical or
electrical)
- Distributor switch fault
- Faulty electronic boards
connection
- Actuator switch short-circuited
Dec 08, 2013 | Krups XP Coffee Makers & Espresso Machines
Krups xp7220 technical error 05
It cannot be an FNF2 and also an XP7220, they are entirely different machines.
Apr 15, 2013 | Krups Orchestro Dialog FNF2 Espresso...
I need a service manual for KRUPS xp7220
Hi Moti,
did you fix the problem?
where did you gave it to fix in our country?
Sep 25, 2012 | Krups Compact Fully Automatic Espresso...
Estou com lexmark e342n fica atolado papel antes de chega no unidade fusora j´s troquei unidade fusora pick up painel operacional
Você pode nos fornecer informações sobre o código de erro congestionamentos quando o papel? O código de erro indicará a área exata na impressora, onde ocorreu o atolamento. No entanto, o melhor é limpar o caminho do papel para garantir que você tenha removido todas as páginas atoladas.
Para obter mais assistência, entre em contato com o Suporte Técnico da Lexmark.
Jan 13, 2011 | Lexmark E342n Laser Printer
I have a Krups XP7220.The waters commes out cold under the appliance. Is the boiler as the guy from service says ? Thanks Ovidiu
Sep 20, 2010 | Krups Small Appliances Espresso Machine
Jul 10, 2009 | Microsoft Windows XP Professional
Jan 02, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Coffee Makers & Espresso Machines Logo
70 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Charles Tidwell
Marvin
Marvin
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
