Computers & Internet Logo
H
HAROLD Posted on May 26, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I do a factory reset on a Compaq Presario v5000 (edited for errors)
Larry Ng
Level 3:
Top Expert:
  • Compaq Master 14,598 Answers
  • Posted on May 26, 2018
Larry Ng
Compaq Master
Level 3:
Top Expert:
Answers
14598
Questions
0
Helped
3278840
Points
66616
Its PC,
PC have many layers, of resets. (not counting lost BIOS passwords of any kind,, that adds to the list , )
layer 1, is BIOS reset, seen clearly in the BIOS pages.
says there, go back to factory defaults (just BIOS)
layer, 2: windows, but you never said which one? XP,Vista, W7/8/10?
To reset windows, there is no such thing, in windows at all.
ask MS that and get that answer, (then tells how, with media)
That means the actual windows, running has no reset.
(but one can spend a week or life time cleaning it....)
what does this RESET, is the HP recovery process.
AKA: reLOADING windows from scratch.
the next step for me is carbon dating your PC,
it's 12 years old now, 2006
but that is the CUSP year that HP started doing F11 KEY recoveries.
so that means i must read the manual to you
here goes.
bingo Page B12. see link at end, 1st google hit, btw.
power on and hammer F11, key verbatim.
this works and takes you back to 2006 with all data gone (yours)
and all added APPS gone, not HP apps there DAY1, those be OK
(reality 101)
now how can this fail, sure, easy as cherry pie it can
here is the list.
  • you changed out the HDD from 2006 to now,
  • you upgraded the PC OS not using HP disks or HP media kits. (boom)
  • your HDD is bad. run full disk tests now. most this old are bad
  • the HDD partition called HP recovery is damaged. super common on 12 year old PC.
  • the PC is sick, (huge list here , hardware!!)
http://h10032.www1.hp.com/ctg/Manual/c00700903.pdf
  • Anonymous May 27, 2018
    short answer RTM (service)
    longer?, F11 recovery. or recover disks.
    ever better post the symptoms first so the helper can be on the same page as you.
5 Related Answers
Anonymous
  • Posted on Mar 04, 2008
SOURCE: Compaq Presario V5000
Cant get my screen to read. it is black/blank. Is there a reset button? Compaq pesario v5000 lap top
Chris
Anonymous
  • 349 Answers
  • Posted on Mar 29, 2008
SOURCE: Compaq Presario v5000 won't turn on
If the laptop posts: (power on self test) and you see stuff on the screen, no matter how short ,do the following:
if you have a bootable anti virus disc use it to check for any viruses , if not
try a recovery disc,
both will try to access the hard drive.
if they do not work,(nothing has changed) nothing comes on the screen.
laptop does not post:
remove the screw(s) holding the cover plate where the ram lives
remove the memory sticks, clean the gold edges with a pencil eraser both sides and re-insert them, (not an ink eraser as it will do damage)
swap them around if you have more than one,
if you only have one, borrow one from a friend or try the ram in your friends laptop ,if that's possible, or take the ram to your local pc shop and ask them to check it for you (they may or may not do that for you)
if you can establish that the ram is ok, and anti virus and recovery disc's do not work,then it is most likely, the motherboard has failed .
good luck with that and let me know how you get on.
Terry
Anonymous
  • 36 Answers
  • Posted on Aug 24, 2009
SOURCE: how to upgrade the cpu in my compaq presario v5000
Go to Compaq's website (Now HP) and find info (KIP) on the max Ghz it will support and what has to be done (maybe nothing, maybe switches or jumpers) set it and "POP" in the new chip!
GL!
Jerry Umali
  • 979 Answers
  • Posted on Nov 06, 2009
SOURCE: I wish to format my Compaq Presario v5000 and
Good day sir/maam, yes let me be of assistance to your task of formatting your Compaq.
Power on compaq and place your windows XP CD installer on the CD drive.
Here are the events that will take place.
  1. You need to boot the CD inside the drive. Go to CMOS setup (usually you press F10) and locate the first boot option, set it to the CD drive. save and restart.
  2. If the boot from CD appears press spacebar, or any key to start the boot process.
  3. At this point windows will load the series of files needed to setup windows. wait for it to ask you a question.
  4. You will arrive at a point to create a partition or where you would like to install the windows Operating system, we usually select C drive.
  5. Next is you need to choose what kind of format you want on the C drive, just choose NTFS, be it the long format or the quick one. (quick format mean the drive is only erased).
  6. Wait for the windows setup to restart, then the CD setup takes over the setup process. Wait for it to ask you questions on where you are, country and the likes.
  7. After setting it up, the XP setup will ask you the 25 letter/number serial code that can be found on the CD case.
  8. the setup will restart, follow the instructions on how to register your windows, or just skip the the process, you can register it later.
  9. On the input login names, place your name and add extra names if you want as login name.
  10. The windows setup is done, you now need the CD that comes with your compaq laptop, to setup all the devices on it, such as sound, video, usb, lan, etc. your done.
If you have questions or met errors along the way, feel free to ask, or if you have a friend who knows how to set it up, ask for help.
Anonymous
  • 4 Answers
  • Posted on Jan 27, 2011
SOURCE: compaq presario v5000 - wireless button broke
sp31891.exe is the HP/Compaq Softpaq that helped me see that the wireless was enabled, but had some kind of software funkiness. It may also contain the driver for the wireless on/off switch for the Presario V5000 series. The particular unit I was working on was a V5005us .
-Brad Chesney
What is the cost of screen inverter of compaq presario V5000
You can find an inverter on eBay; here is a link. They range from $5 to $15 with free shipping.
2helpful
2answers
Compaq presario v5000 won't stay
sounds like overheating , probably due to the cpu or gpu fan/heatsing loosing contact, even a little knock could have caused this
My compaq presario v5000 a 5240NR was working fine
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness
1helpful
Computers turns on and turns off in about 5 seconds by itself
may be your reset button is pressed on....so you better unscrew your computer and then remove the plugged in botton that is lined from reset button (u can follow the layout diagrams inside the computer)... ..i think it may help you ... later you can take out the pressed reset button as well....
BSOD when volume turned up on compaq presario v5000
This is usually caused by a fault on the Motherboard, nothing much will help in this case except replacing the motherboard.
Driver
Since there are two diferent V5000 and you dident tell us whitch one you have il give u both models, chose the one you have and download the drivers u need.
Compaq pressario v5000
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=499847&lang=en
Compaq pressario v5000T
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=1832426&lang=en
3answers
Could be a stuck key somewhere, has anything been wasted on the keypad, tap the keys one by one to refresh is. Could also be that the keyboard is broken.
Fixya me ... thanks!
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
