Question about Neff Cooktops
I have a Neff induction hob T40B30X2, the fuse has tripped out, when we turned it back on error code e-1 flashes on the hob. cant find any reference to it on the Neff website. anybody have a clue?
Posted by Michael Quartermaine on
5 Related Answers
Anonymous
SOURCE: Neff T4344 hob, need instruction manual???
Try http://bshappliancecare.com/Neff/customercare.html
You can download a PDF manual for the T4344
Regards
Jon Morgan
Posted on Feb 06, 2009
Anonymous
SOURCE: Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Posted on Nov 06, 2009
Anonymous
  • 4 Answers
SOURCE: My Neff induction hob has prgressiely getting
Hi, if you take off the magnetic knob & let it flash a little longer, then switch off & on again it will work. Ours is doing the same. The book says it needs cleaning, as do the customer services people but I've cleaned & cleaned it & I assure you it's spotless. You don't have to wait 10 minutes though to start cooking, just 1 after switching off. It is very annoying though & I think we will be getting an engineer out to look at it.
Posted on Dec 15, 2009
Anonymous
  • 71 Answers
SOURCE: SMEG SE435X-1 60CM Electric hob. Keeps tripping fuse
It's possible that one of the burners stay on for a long time, which cause one of the wires to overheat, breaking the connection and touching the body of the unit, please turn the breaker off and check for a loose connection, replace the wiring if you feel confortable doing it yourself or contact a technician.
Posted on Jan 06, 2010
Alan Edmonds
SOURCE: when turning on my 2 year old Neff induction Hob
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
Posted on May 29, 2012
My Neff induction hob shows an error code of er 22?
That means circuit board error. You will need a replacement or tech.
Oct 11, 2018 | Neff Cooktops
F4 code keeps flashing the hob is not hot as I have not used for a few days
Go to this website and they have a online helper to assist you with your issue. This is free. http://www.neff.com.au/service/support/induction-cooktops/not-working
Dec 04, 2017 | Cooktops
Hob ceran replace with new induction hob
Need looking at by NEFF , a big job .
Mar 16, 2015 | Neff Cooktops
Neff induction hob error message flashing rear left r rear front E rear and front right 2
sir pls send me the answer when we put a pot on induction.after 30 minutes igbt get short
Dec 21, 2013 | Cooktops
Induction hob neff T4243 has cracked will I need to replace it
Did you crack your hob by means of impact or did it happen on its own accord?
I have a neff induction hob and has just cracked in 3 directions while cooking this evening. I am just trying to determine if there is a common fault with this neff product or I am just unfortunate. Mine is under warranty and have a engineer coming on Monday, so have the whole weekend with no hob as I have been advised not to use it.
Many thanks
Feb 28, 2012 | Cooktops
Glass on neff t4243 induction hob has cracked
hi,
is it possible to replace a cracked glass on my Neff induction hob?
where would I get the glass for my Neff induction hob replaced?
is it very costly?
the model number is t4483x2/09
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
Jul 28, 2010 | Neff Cooktops
My Neff induction hob has prgressiely getting worse. All the lights start flashing and only hob will work. But after 10 mins the other hobs start working. The flasing gets worse if you try to start with...
Nov 29, 2009 | Neff 23 in. T1443 Electric Cooktop
Jun 18, 2009 | Cooktops
Cooktops Logo
323 people viewed this question
Top Neff Cooktops Experts
Lee Hodgson
Lee Hodgson
Paul Carew
Andrew Taylor
Andrew Taylor
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
