Televison & Video Logo
Michele Schwartz Posted on May 25, 2018
Model PMV207SM 1SS GE profile built in Microwave The panel lights up; the clock, vent , light work fine, but the control panel is "locked".
Nothing happens when you press ANY function. The unit is 9-10 yrs old with light use and no problems ever. Hope you can help. Many thanks!
Hans
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 26, 2018
Hans
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
53
Points
Is it t h e child proof lock? Press CLEAR/OFF button for 3 seconds to see if it unlocks.
4 Related Answers
Anonymous
  • 38 Answers
  • Posted on May 09, 2007
SOURCE: Nothing happens when you press "Start"
PLEASE CHECK IF DOOR IS CLOSED PROPERLY THOSE HOOKS ON THE DOOR ACTIVATE SWITCHES ON THE INSIDE OF MWAVE OPEN COVER AND CHECK IF HOOKS ARE MAKING CONTACT WITH SWITCHES .COULD ALSO BE TOUCHPAD FAULT YOU WILNEED A TECH
vanessaaboyd
  • Posted on Jan 15, 2009
SOURCE: When I press Start - Runs for 5 seconds and stops.
I tried the "side dish" option with a glass of water in the microwave. The turntable continued to turn - it didn't turn off in 5 seconds- but then smoke started coming out of every vent. I think that killed it. I decided to go buy a new one.
Anonymous
  • 1606 Answers
  • Posted on Aug 08, 2009
SOURCE: GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Anonymous
  • 6771 Answers
  • Posted on Jun 26, 2012
SOURCE: Control panel on GE Profile Spacemaker microwave not working
You are right the control panel is very expensive, you can try the filter to see if you can get it working, but I must admit a new microwave oven sounds appealing.
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • 0helpful
    I am realtor. Just sold home with built-in over the range GE Spacemaker 2.0 microwave oven (JVM 2070). The three buttons on lower right hand side (vent, boost, light) are missing. You have to stick...
    Yes. You can find handy exploded views and order parts by model number here.
    To aid in disassembly, the service manual is HTML clipboard here.
    At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
    16helpful
    I have a GE Profile Spacemaker Microwave Touch Pad does not work
    Sadly, GE does not make individual parts available for these controllers, so they cannot be repaired.
    You have to replace the control panel sub-assembly (part number WB07X10733 in your case) and the best price I've found on that is $370.32 here (compared to $483.25 direct from GE).
    In my opinion, this does not do much to inspire brand loyalty...
    Or you may be able to find a whole oven on eBay for about that or less.
    Sorry to bear bad news. Good luck.
    Not working
    It sounds like 2 separate problems:
    1) One of the cooktop lights may have shorted. Sometimes this happens and causes damage (repairable) to the control circuit board. Sometimes it will result in the lights or fan not working, or not turning on.
    2) You may have a bad magnetron. See this FixYa solution.
    Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
    William E. Miller, AS-EET
    [email protected]
    http://www.microwavedisplay.com
    Microwave Oven Control Panel Repair Nationwide
    Ge Profile model jgb900 has error codes & oven doesn't work
    Hi, this is a lock switch malfunction and you may need to replace this.Check the wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
    Top GE Televison & Video Experts
    ExpressFiX
    ExpressFiX
    matt martin
    matt martin
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a GE Televison and Video Expert? Answer questions, earn points and help others
